Suspension Poll
Southern Ontario
Hello all,
I am going to be ordering my suspension and would like to hear from some of the members. on what you have.
What tire size?
What Suspension Kit?
Would you buy it again?
Where you would buy?
and the big one if you were to piece a system together what would you get.
ie BDS springs, OME shocks, shackles, pins ect.
Where's the poll?
You want a short term bandaid for the kidney jolting leaf springs or a long term fix of the problem? LOSE the leafs & adapt a coil spring suspension. Just look at some of the new TJ's for ideas & study up on link suspensions, that's what I did. It was WELL worth the effort! Link it out dude!
what kind of vehicle? what are you looking to do with it? will it spend time as a daily driver or trail only? how much money do you have? what's your fab skills?
want bumpier ride? go soa.
less bumpier ride? keep sua.
even lesser? coil spring suspension.
i kept the sua with a 4" lift.
so soa is the bumpiest ride?
technically speaking, wasn't advised to use SOA since i was told that at higher speeds the ride becomes bumpier. would i scratch that advice???
You should not ever again listen to whoever gave you that advice. And you should also realize that nothing is ever that simple.
And not trying to sound harsh... But be careful about volunteering advice unless you have more than someone else's heresay to base it on. :(
Mark...
After several hours of reading and looking and guessing.... I have decided on a 4" BDS with HFS 11/2 shackles. Thank you for everyones input.
