- Joined
- Nov 23, 2016
- Threads
- 87
- Messages
- 2,571
- Location
- Valdosta, Ga
- Website
- www.cruisersontherocks.com
You won't need a very long tape measurerCan confirm, I have some up and not a lot down. I guess I should measure or something
I hear ya. I got 6 up and 6 down.![]()
I’ve had poly bushings for a year now and still haven’t heard a squeak from them. Rubber is better for lightweight trucks. Either will work thoOEM rubber bushing is flexible while poly is not. Poly bushing will not dampen any vibration or noice.
I'd love to start a new thread just to ask this question, but probably not necessary. Has anyone tried these super pro bushings with stock OEM shocks on a 100 Land Cruiser? I'm getting mixed ideas about what affect this will have on overall ride quality. My understanding is the Super Pro shock bushings combine the durability and handling benefits of poly, as well as the benefits associated with an all rubber bushing, rolled into one, due to their proprietary blend.
Just trying to see if this will be worth upgrading, since I'm probably going to install some nice new OEM Toyota shocks I've had lying around now for a while. Even though, my stock OEM shocks seem to be doing just fine. My shock bushes are looking pretty cracked and squashed last I peeked in there, so I figure now's a good time to do this simple upgrade.
Front Shock Absorber Upper Bushing Kit
Reliable suspension part to suit your vehicle. Improve comfort, control, and long-term durability. Shop Now!superprousa.com
The LCA bushings from SP are a huge improvement over OE rubber for heavy vehicles (my truck comes in around 7,200-7,400 lbs.)Still haven't "met" anyone yet that has the Poly LCA bushings... but Patch seems to have had them in for about a year now? so, regarding those poly LCS bushings... Howzit?
Bushing deflection with OE rubber, even if it's new, is a pretty big problem- especially with larger tires. Creates rubbing and uneven tire wear. Not many people talk about it. Poly requires more maintenance (regular greasing) which deters many buyers but for extreme conditions its vastly superior.
Im definitely not against Poly myself... but there are some strategic bushings that benefit more than others.The LCA bushings from SP are a huge improvement over OE rubber for heavy vehicles (my truck comes in around 7,200-7,400 lbs.)
I sure do!Do you carry these? Might want to give it a shot. 300K on the factory lower arms and I’m thinking that’s where a lot of my slop in steering is.
