Superflex radius arms
The oe radius arms vs using a radius arm with a joint in the middle like in an aftermarket rubicon express type arm-an arm that would flex so much better and compromise nothing off road. A radius arm such as this performs almost as well as a three link yet compromises almost nothing in terms of stability. The 3 link makes several compromises and requires cutting
The joint in the middle has so little to do with flex - the Jeep upper mounts sit inboard of the lower mounts and the joint allows for that angle more than anything through a range of motion.
What makes the y-link flexy is the vertical distance between the lower and upper bushings and the fact that the Jeep bushings are large and relatively unrestricted in terms of ability to deflect. It's not like the rear of the 80 is restricted in flex, and that's for the same reason - the rubber is not highly restrictive (it can deflect). The front 80 series arms use tiny bushings in a narrow arm placed close together on a horizontal plane - that's why they are so restrictive.
Even a stock Jeep tinfoil arm from the mid-90's had no issues with flex - it was the severe link angle, and the tendency to drive the axle downwards, plus the crappy road ride, that led to the development of the y-link radius arms.
Those arms have many compromises offroad, from clearance to suspension dynamics. You are trading one problem for another in that swap, and those big bushings that allow more deflection offroad will allow more deflection onroad, like when you hit a bump at speed on the highway. Not fun.
... expedition ...
Hope you weren't thinking of me, I don't even own a tent. Most of the time we stay in hotels, in the words of one of our group; smart travelers take advantage of available infrastructure!:hillbilly:
... the factory radius arm needs to be tossed in favor of a design that places a flexible joint between the the two axle attachment points. Why has this been done only once on this massive 80 forum?
Not sure what you are referring to? There have been a bunch of differing link, modified arm setups done over the years, with varying results. A few have threatened to bring out kits, that has never happened. My guess is they hung around or wheeled an '80 long enough to learn the dirty little secret. They work well stock, so few are willing to spend big $$$ for something that is going to have little gain for most users.:hillbilly:
Some keep referring to heeps, I have never owned one, but have some experience with them, my observation is: Most have significant deficiencies from the factory (short wimpy sheet metal arms, etc) that don't work well and easily break when wheeled. Once broken, may as well "upgrade" to longer, stronger stuff that works. The cruiser stuff may not be perfect, but it works and is just about bomb proof, so no "need" is presented to "upgrade".
So now you know more than me and the Vehicle Dynamists. I shouldn't say this but, its time for one of my favorit quotes
"What you've just said is one of the most insanely idiotic things I have ever heard. At no point in your rambling, incoherent response were you even close to anything that could be considered a rational thought. Everyone in this room is now dumber for having listened to it."
I probably don't know more than the Vehicle Dynamists, which I why I am smart enough to leave well enough alone, especially since I am the "Vehicle Dynamist" for my own rig.
And I have a better quote for you: "None of us is as dumb as all of us". 4x4 web forums do not make people smarter - they make people do things that make no sense for their actual usage.
I am yanking your chain because your posts are nothing more than Dick Swinging. If you are going to note my observations as incoherent, prove me wrong. I suspect you are in fact dumber for having read it, because your personal wallet just opened a bit further to prove a point that will never yield a positive ROI.
I have an idea :idea:
Post up a diagram of your arm placement, front and rear. Post up all of your suspension geometry calculations that go with that arm placement. Then post up the coils that are going to work with this suspension and retain a proper load bearing capability. Post up the shock you have chosen to go with your design.
Post up your timeframes to bring that to market, and the projected cost. I really want to watch another thread that goes two and three years old without anything ever coming to market. It's been awhile since we've had a good teaser.
What are the specs of your 80, BTW?
There is too much "I thinks" going on here. When it comes to improving the radius arm in this app I KNOW because I have seen and felts it's application with my own hands on the steering wheel on multiple rigs.
In the mornings I round with the residents and med students of Lloma Linda university. We go from room to room in the hospital and discuss the treatment plans for the patients on our service. There is always this new presenting intern who reads me off a bunch of lab values and pulls out the pile of medline articles he printed off the night before and then goes on to instruct our team on the proper course for so and so patient because that's what the algorithm says. Then I poke my head in the patients room and within moments find that the resident spent all night developing a wonderful treatment plan that didn't apply to his patient. His diagnosis was wrong from the start. He didn't need books or tests. what he needed was experience with the disease process. After the disease has been witnessed and treated enough times the treatment is automatic.
How many have driven a proper flexy radius arm like the rubicon lift for a tj? Since when has an 80 rubiconed radius arm been just so so. My brother runs a rubicon lift on his tj and so does my father in law. I have driven both plenty. One of my wheeling buddies wheels the same lift. the rubicon arms ride as good as stock on the road save for the detriment of a higher center of gravity. And off road they flex great. And your 80 is only a half ton more than a tj (less if not piled with unneeded body armour) I don't know what you guys are talking about when you say all radius arms are the same. I run rubicon express rubber joints in my rear end. It flexes like mad. The only bad thing about the rubicon express arm is how it can wear out the rubber joint. All the flex has a price. But the joints are cheap and easy to replace. It is as easy to replace rubber as it is to service johny joints. And the front 80 arms are so damn long that deflexion would be minimizes.
I don't want to seem arrogant but you guys just don't know. You are choking on the coolaid. You are just wrong. The rubicon radius arm is the simple solution you seek: great highway dynamics plus great off road flex.
Dusty, radius arms are fine for the street, but when it comes to flex lets at least put this in perspective. Im coming from the concept that if it starts to bind before I bottom out my 16"s then its binding. I do have expereince with these are you speak of. And they do exihibit torque lean. This is my deffinition as Walking Eagle said, he doesn't think he needs it. Thats my 2 cents.
Lots of pretendgineering going on here. Lots of opinions and little or no data.
It still amazes me that this discussion still comes up. Make your truck ramp 1000 and still be able to run 80 on the hwy with factory handling dynamics, and you MIGHT make it 100 ft further up the trail than your buddy with his off the shelf, bolt on, aftermarket suspension kits and 35s.
It amazes me every time this discussion comes up someone thinks everyone wants to ramp 1000. I don't. I want a little more comfort, and for the frotn to stop pulling me over on ledges. Doesn't require ramping 1000, nor a full 5 link. Not looking to turn it up to eleven, just want to get rid of the distorsion at 8. If you don't get the turning it up to 11 reference, you have my simpathies :)
That's the one I was thinking of, that I couldn't remember.
Problem with this crowd (80 owners) is we have very expensive vehicles, but we're all cheap skates. :) We get lockers for free, a decient lift for a grand. Then when we want to go beyond that box, the $2500 + for arms or a link system freaks everyone out. Oh well, it is what it is, it's usually interesting to read though.
this is the problem with the 80's oe radius arms. i suspect we are talking about the same thing:
the oe radius arms just dont flex. the problem is simple and the fix is simple. there is this recurring situation when wheeling where a wheel falls away from the body into space. could be into a hole or off a rock or any of a number of situations. that axle weighs hundreds of punds. if the suspension cant flex, the wheel just "hangs" there to some degree instead of falling into the hole. whatever degree of hangingness adds weight to the offending corner causing it to tip into the hole.
now add to this hang phenomena the tension bound up in the stiff suspension. the tension in the radius arm causes the axle to want to spring back when it is flexed.
the whole mess is most aparent when one is trying to wheel quickly which i love to do. the truck is rocking and tipping violently. which wouldn't be so bad if the 80 had low gearing-but it doesn't. the 80 wants to wheel fast. it is not a crawler.
my front end is now looser than my rear. i can fly through boulder fields now.
You guys convinced me, after following this discussion for a couple of weeks, I'm convinced that the 80 suspension is substandard and not well equipped for 4 wheeling. I see no hope. I am selling and getting a Wrangler. :flipoff2:
There is too much "I thinks" going on here. ...
My “I think”:
Yes I driven, spotted, etc, radius arm rubicon lifted heeps, they work OK. It is all about application and use, IMHO in the ‘80 application, if going to the effort to make new mounts, design around/move the tie rod, would go with something better than replacing radius arms with radius arms. When I design something, look to make it as strong or stronger than stock. The front axle load is carried by 2 bolts, IIRC 18mm stock, So in domestic ~3/4” would be good, I haven’t seen any of the joints in that size, load carrying capacity?
My experience with plastic joints is, they work well on relatively light rigs/buggies, especially when they don’t see a lot of road/DD action. When the FJC was new, a couple of my wheeling buddies got HD rear arms that used them. Looked to be a nice setup, they used the joints with the biggest bolts available, but were significantly smaller than stock and the torque number significantly lower. Came with step/spacer washers to take up the difference, grade 8, lock nut, hardware.
Even with frequent greasing, the plastic got pounded out often, almost always loose and often replaced, maybe overloaded? The bolts were loose at every retorque, my “I think” is they were overloaded for the application. I know of 3 times where bolts fell out/broke/failed on the freeway. The last straw was on a trip, in LA freeway traffic, in the fast lane, huge mess. They now have reinforced (angle iron) stock arms, still flex the full amount that the shock allows, but don’t squeak/clunk and the bolts stay tight, don’t fall out.
It all depends on application/use, but I have not seen any that I would feel comfortable with for my rig use. Especially on a radius arm were 2 carry all of the axle loads? Also don’t see the need, my modified arm setup flexes, drives, etc, well and uses stock bushings. Like the super flex arms (remember them, the subject of this thread?) they are 100% bolt on, requiring zero welding, rig mods.:hillbilly:
Sounds about right, you want bigger ties, more flex, on and off road ablility, but you dont want to pay for it, I cant help that. If thats what you want then you have to pay for it. Some one told me along time ago when I first got in to this hobby, "if you change one thing you have to change everything". And it's extremely true.
Yes thats it Nay, I'll post all my ideas just so that with your infinite wisdom, you can knock them down as invalide lame or retarded. Brillant idea! Lord knows your the expert here.
Unless of course you are going to plant a V8 into it, hack the body, and trailer it to the trail head.
:hillbilly:
yeah, but what hillbilly would do that?
My “I think”:
2 9/16" (standard johny joint bolt) grade 8 bolts will be the last thing to give. the bushing will implode or the mild steel bracket will tear before the bolt will sheer. i have never seen or heard of a tightened 9/16 bolt failure. a pair of 3/4" bolts are untouchable. i run a pair of 3/4" bolts on my rear radius. the broblem with metric bolts is that there are no aftermarket bushings.
yours friend's aftermarket fj kit just sucked. i know from experience that the smaller rubicon bushings just dont last as long either. go big or go home
i too have seen a lot of trashed bushings. durrable and flexable bushings are rare. there are 2 exceptions: i have been using the large rubicon express joints for 3 years and they are awesome. i also helped my dad build a custom long arm lift for his tj last year and we used the new balistic rubber joints. i believe they are just as good and they come with a 1.25 shank so you can use them interchangaly with the 2 5/8" johny joints that are sized for the industry standard brackets (rubicon joints are also 2 5/8").
and the radius arm is not the best pure wheeling solution-the 3 link is. i champion the better radius arm because it is a simpler fix than the 3 link. the 80 tierod doesn't need to be moved to do a better radius arm. just fab around it
IMHO - There are good solid reasons to stay with the stock arm, good solid reasons to change arms, and good solid reasons to go 3-link or X-link. The trick is to know what you're looking for, and to be honest with yourself what you really need and are really going to use it for, and what gains are to be had. I see it as 3 main different groups of people...
1. There are people who do more expidition and mild crawling and place a premium on daily driving and hwy performance.Those people are gennerally happy with the current set up and will continue to be happy w/ the current set up. They generally run 35's max and don't want lots of body mods, either on purpose (opened up wheel wells) or on accident (rock and tree rash).
2. There are those who have pushed the evelope just a little further. They run a bit harder rock trails, but still aren't into trailering their truck. Buggies aren't an option cause they need a comfortable cabin, and perhaps even have a couple kids that are with them every time they wheel. They find the limited front flex hinders them a bit in some of the situations their chosen terrain presents them with. They still want good hwy manners. These folks are candidates for Y-links or Superflex arms. Not alot in this group have gone to the next level as they either don't have the coin to ship in Ausie arms, don't have the abiltiy to do it themselves, or don't have the moeny to pay someone else to do the work. I'm in this group - I've gone to 37's, opened up wheel wells, and put really long travel shocks on the truck in preperation of that next step.
3. Those that want the most capabile big beast out there. They are willing to accept body damage. They are trying the toughest obsticals they can fit their tank down. They might be buggie candidates but still have families to wheel with, or just have so much invested in their 80 that they're not willing to switch. They're on 40"+ tires and willing to chop stuff up to get the performance that they want off-road. It's a mixed bag as some want to drive on the road, and some have religated the truck to a trailer. This is a small group - I imagine this is limited not only because it's simply a small group who want this rather than a buggie but because the risks of screwing up what already works are high. The buy in is really high too since there isn't a bolt in solution, you're either on your own to do it or you're paying someone else to do the work for you. 3 linking or X-Link is what suits this groups needs, or perhaps a 5 link.
I think people get frustrated when they don't realize what group they're actually in. Or when they have nay sayers telling them that they shouldn't be wanting to be in the group they want to be in (pun intended). Or, when they know what group they are, and just don't have the money to make that a reality. Such is life.
Just don't tell me the stock arms work for what I need when I know that they don't and you've not wheeled with me to see where they are limiting me. And don't tell me I need to go whole hog, when I know the trade offs are too much for me.
Back to the origonal topic, the Superflex arms seem to have the data to support them being a valid option for those in group 2 who can aford to try them. If everyone who either wants to prove they don't work or prove that they do work will send $100 via pay pal to rallybug@yahoo.com, I'll be happy to prove or disprove it :)
