Superflex radius arms
Nay, with all do respect I completely disagree with your theory when you say, "everything we do to perform better off road is going to make our on road driving worse. To a point yes, there is no getting around the fact that your COG is higher and larger tires that increase un-sprung weight don’t help either. The vehicle will always lean more in a turn because of the COG and because we are allowing it too by softening the springs and lengthening the shocks, but if it’s a controlled lean and isn’t scary then in my eye’s its acceptable. If in the end it reliable, predictable, drives in a straight line and doesn’t wander but still flexes as expected then you’ve done your job. This is not impossible, as I stated earlier, start from scratch and think out side the box you can build a great suspension that performs extremely well in all conditions.
[/SIZE]
I agree with this completely - I use my 80 for family safety in severe winter conditions. It drives 70-75 mph with a near stock suspension ride all day long, and it is incredibly capable offroad.
Most of that is the base vehicle, however. The 80 is just such a solid platform, what you can do with it suspension-wise is largely a tuners' game. Most of the 80's on this forum are running a suspension designed for high speed overland travel (OME). The springs are stiffened (in many versions) to account for adding a lot of weight, and the shocks are highly valved to control the whole thing with a typical travel bias to up travel to account for suspension compression at speed.
You take that offroad to rock crawl, and you are not going to like it much more than I would like my suspension with a extra 1,500 lbs of weight at speed in rough terrain. That's why you will see posts on this forum of 80 owners picking up tires in what is not much more than 2wd terrain, and it is also why you see me chopping my frame and running tube bumpers to avoid adding weight (or excessive lift).
I am all for redesigning the suspension. I think you will find it more difficult to achieve than you believe, because this rig has such a huge area "in the box" and so little area "out of the box".
What I mean by this is you can easily run 37's on a bolt-on suspension that will still drive like a Jeep on 32's on the highway. That lift will not exhibit any suspension dynamics that are likely to surprise the driver or create an unpredictable situation offroad. I drive 9 hours to Moab with :princess: and four kids, and the drive is so easy that :princess: jockeys for wheel time. Once in Moab, I run most of the trails in low range AWD because it is easier on the steering, locking up for bigger obstacles.
Once you get out of that box, several things happen. The first is that you just went up to a damage mandatory trail class for a rig as big as an 80. I don't care what you do with the arms as you now have a major problem with breakover angle due to the excessively low hanging 80 series frame. This means you really need to by at a 6"-7" lift, and 40"+ tires.
Now we are talking about vehicle that is no longer dual purpose (whereas the "in the box" 80 on a 4" lift and 37's is the ultimate dual purpose rig for a hardtop 8 seater). It is probably headed for a trailer with custom Dana 60's and a body chop once flopped/rolled.
When you go to sell it, it will be worth just about nothing, because the only person who wants a beat up 80 series trail rig is the guy who started with a nice stocker and wouldn't give up to find a platform better suited for the trails he wanted to run. This scenario bats a thousand.
It's the guys with the current beaters, or beater wannabes who don't have the kind of trails that will actually trash an 80 quickly, who are mostly disagreeing, and that's my point: the only question for them is sunk costs, and chasing guys on the wrong side of sunk costs in an extremely limited market is about as bad a case to achieve a good return on investment as you will ever find.
People stopped oogling OME a decade ago, and half the freaking threads on this forum are about how to make that crap-ass overpriced suspension sit level so the truck doesn't look stoopid. You have no idea what you are up against :D
And how many 3 - link owners have changed swaybars? Messed around w/ swaybar rates? Shock rates? Spring rates? How many have changed the frame emounting points? Last one I looked at just reused the stock mounting points. What are the chances that the stock radius arm mounts are in the pefect spot for the perfect length 3-link? Slim? None? 3-links for taco's seem to work pretty good from what I've read.
Taco's have rear leafs :flipoff2:. I don't think many 3-link 80 owners have messed around with this other stuff, because they took it on a couple of trails that need a 3-link and realized it was still to big, wide, heavy, and low hanging to compete. Then they sold it rather than trying to fix those problems with swaybars and spring rates. How many times has Action Jackson's 80 been sold now? I think it was on owner #4 a year ago and ended up for sale in a corner lot in Colorado Springs as a trade-in.
One thing that three links do for sure is make built 80's affordable for teenagers.
Well, that's the DUH statement of the year. Unfortunately, there are people out there 3 - linking not giving any consideration to balance between the front and rear. It's not the 1st or last time I'll speak of balance when these topics come up. I'm very Zen that way.
Dude, I'm still waiting to see those homebrew SE arms you were going to make before you get all Zen on me. I'm starting to have images of Zach playing Blackjack here. :lol:
I think you're missing a NOT in there - as in the correct geometry for a Cherokee is NOT correct for an 80.
Of course, because achieving the right measurements in a parallel upper/lower arm design with one upper arm removed in a solid front axle application is mostly dependent on the rear suspension. Unless of course you are finding a lot of room to get really creative with those upper mounts.
You're joking right? Please tell me this is poor sarcasism - cause if you really think all that's needed is to dump a few #'s in a spreadsheet.... welll.... then I'm not gonna continue to discuss as there is little reason in it.
I have $20 that you'll continue. :beer:
Or you could share. Let's remember why Jeeps, both styles of cherokee and the wrangler go to radius arms in a bunch of suspension systems to begin with. There isn't room for a proper length 5 link w/ correct angles once you go beyond a certain point, unless you drop some mounting points.
Your 80 series arms have a curve around the axle and then tuck up before running to the mount. They are cast with a small lip, and they slide very, very well - you don't ever get any "dent 'n hold". They are also about 30" long.
The Jeep y-link radius arms are generally 36" long (I don't know if they make a shorter arm now). They are straight, which means they hang down lower than the 80's radius arms and will have a frame mount about 6" further to the rear. This will be a major loss of clearance. They will slide like your rear LCA's slide once you have some weight on them.
I spent plenty of time on y-link radius arms on a 7" lift with a 101" wheelbase and a front end that flexed like crazy. I have never hung up on my 80 front arms on a 4" lift and 112" wheelbase, and its not for lack of contact..
Word to the wise - those front drop brackets may be a really bad idea in this application.
I see a lack of it. The front is pulling the body down and forcing the rear end to unload. If it was a really big steep drop you'd see it even more.
I think gravity was pulling the body down :D. From a driver/passenger perspective, that was totally smooth and predictable. Engineer in an unloading long travel Jeep y-link radius arm front and solve that problem.
What keeps you away from reading any of the half dozen posts in this thread or listening to the video saying it keeps the swaybar? It's one thing not to know, it's a different thing to have been told over and over and still state incorect information.
The counter posts I have read saying you can't, generally not paying attention or caring. It's not a big deal. Y-link Jeep arms are better anyway.
Pros
Lots of Jeep people run them to correct for their itty bitty T-rex arms
You can make money in a Jeep market even selling to broke-ass kids
You will actually have an aftermarket to resell them
Cons
Loss of clearance on a clearance challenged vehicle
You have to give money to Rubicon Express
Jeepers on the trail will notice and then ask you about birfs, and which point you'll talk about the superiority of birfs and then grenade one on the next obstacle while they watch
Sloppy Jeep rubber bushings (you'll really love those interstate expansion joints)
Front end unloading on moderate travel suspensions, requiring the ever popular limiting strap design
And of course...spending twice the money on 4x the mods while other people actually wheel
Uhm - no. The chassis mounts are stock.
I don't know how the 97 swaybar mounts to the chassis, but on the 94 Oz version, the stock mounts are two hinged pins the sway bar bolts to that are needed to allow the suspension to droop. Ignore articulation, and assume the left and right side of the axle rise and fall together. As the axle drops away from the body the chassis 'hinges' rotate forward allowing the swaybar to go with the axle, then as the axle rises the hinges rotate backwards.
Adding 2 extra hinges into that design turns a swaybar into a noodle.
If your swaybar mounts directly to the chassis and is then hinged at the axle the Superior adapters would work fine.
was thinking about this, for some reason I thought it was solid at the chassis - I don't remember it moving when I put my swaybar drops on, but I don't remember it not moving. That would explain why the #'s with and without swaybar ont he superflex arms are so close. It'd be worth asking them how they address that issue - otherwise I'm just speculating.
Well, that's twice in my life I've been wrong - thanks for not being nasty about it like so many on the web. I guess my "uhm, no" probably wasn't the nicest, sorry bout that.
It's amazing how starting your truck on fire delays stuff....
I think you're supposed to set fire to your rig AFTER you do some stupid, irreversible mod. :flipoff2:
Homemade superflex arms are reverable - especially when you have an extra set of arms laying in the garage.... Actually, I'm thinking I started it on fire WHILE making some stupid irrevesible mod...
:deadhorse: Sorry :)
You many have been around suspension mods for 12 years now, but everything you learned was derived from a very bad understanding of what is really going on.
People stopped oogling OME a decade ago, and half the freaking threads on this forum are about how to make that ****-ass overpriced suspension sit level so the truck doesn't look stoopid. You have no idea what you are up against :D
So now you know more than me and the Vehicle Dynamists. I shouldn't say this but, its time for one of my favorit quotes
"What you've just said is one of the most insanely idiotic things I have ever heard. At no point in your rambling, incoherent response were you even close to anything that could be considered a rational thought. Everyone in this room is now dumber for having listened to it."
I try to respect where people are coming from. And if I was coming from a Jeep Cherokee to an 80 series, I too would likely think there is nothing that can be done to improve perfection. :)
I spent some time checking out your website
(Great read on suspension dynamics) and it looks like you have some solutions for the minis. I'm interested to see what you come up with for the 80.
Me too! I wish he had something availible now... I need to get something done this winter as I have bent my stock radius arms. The benifit for me is my 80 is trailered 90% of the time. :cheers:
Thanks guys I appreicate that, they took long enough to design so I guess they better look good. And thank you on the story too. That too took awhile to produce. Other than low roll steer and some adjustablilty I cant tell you what Im doing, I'll be working with someone here in a few months and will see how far it goes. Part of it is shock tuning not just brackets and such, if you can wait great if not I understand.
Thanks
Thanks
Well, many have been waiting and wishing for years, so what's a little more wait.
There have been some false starts - I believe Crusier Outfitters had a 3 link they had developed for the 80 series, but it was very expensive (at least for the cheapos like me on this list). Then the x-link from down under got some interest, but was expensive for an unusual technique and 1/2 were screaming "floppy jalopy". It's hard for most of us to spend $1500 or more on something we're not sure will work. I think that's the same issue with the Superflex arms.
I'd say, in my opinion, most aren't looking for maxing out 14" travel shocks in the front (though I'm proud to say my truck has them) - most are looking for a little gain. The home brew 3-links have too many drawbacks and too few people have the time, money or expertise to really tune them right (even though some claim it). For the rest of us, the hitch pin mod, Y-link ala Rubicon Express, Superflex arms, these all seem to be in the right relm. Obviously more than one way to get to that ideal space though.
Just a little more that's all we're after. Just enough to put this tire on the ground..... and of course, still be able to drive from Tulsa to Moab at 80 w/ two kids in the back w/o any worries of safety. So far, the two most likely to suceed at that I've seen are the Rubicon Express arms, or the Superflex arms w/ different swaybars are the most likely to deliver of those offered today.
