Superflex radius arms
Cut the brake line bracket off the axle, since there's no other way for the plate to fit, and nudged it out of the way.
Removed all the clamps from the lower DS frame, sway bar, and the rear axle housing for the sensor line, and pulled slack to allow a little more clearance.
Need to reroute the hard line and extend the other, or figure a way to run it down the arm once the sway bar is removed (left it on merely as a router for these lines and the locker) which leads me to another visible concern.
The braided brake lines may not be long enough, which sucks, but even worse is the WSS line (have no clue how to extend) and locker may be too short, as well.
Anyone confirm? Lift time will be minimal, and want to be prepared for issues, in advance.
Delancy said:
Not that I was keeping front sway, for now somewhere to attach lines to, but it's BENT the drive shaft.
Corrected, for accuracy.
Keep in mind, it hadn't been driven. I didn't pay close enough attention to the clearance, though.
After pulling front sway, too ( no sways ) the body roll is more than what I feel comfortable driving 80mph on the highways. Not sure if the OME Ls (temporary) aren't capable of minimizing, or if a better shock is capable of controlling more, but trying to minimize.
There's no way to adapt an anti rock type bar to the front of the 80 and the OE bushings are shot, so looking at replacing the OE sway bar links, lengthening 2".
Superior did confirm that the brake lines and WSS routing is different on the US axles and hasn't been an issue in Oz. Need to find a way to relocate the WSS line to the top of the diff and protect, all while creating enough slack to eliminate contact on the upper SE bushing bolt.
Preliminary measure to minimize the destruction of the OE frame mounts as documented by others, in favor of a top of frame rail, aft mounted torsion bar.
I still don't know that the inherent body roll can be minimized with only a rear bar (going to try the OE's again, to aid in sizing bars properly) and trying to conceptualize a similar torsion bar assembly on the front of the frame for the front axle, but a lot of moving components that's real estate varies with different positioning.
Some anti roll characteristics are still desirable off road and the torsion bar (anti rock style) do not have the same negative impact on wheel travel, but don't offer the same OE characteristics....all assuming they can be made to fit.
Not sure if you're looking for sway-bar opinions or not, but my truck has very little body roll with the rear sway bar only. I took the front sway bar off back when the truck was stock, and never looked back.
However.... whenever I remove the rear swaybar, it has quite a bit of body roll. Enough, in fact, that I just leave it on full-time.
Not sure about the "destruction of OEM mounts"? I've never had a problem with them.
All about opinions.
They appear to be magnets, considering how low they hang. Others have complained of destroying the frame drops (which I'd need).
Regardless, going to reattach the rear with a cobble drop to see if it minimizes the roll. I don't think it's correctable in shock valving without a rear, at least, but planning an Anti Rock for permanent bar.
It is very correctable chris. I dont understand much of what you talk about :). Distruction of oem mounts, ome Ls, going to try the OE's again, to aid in sizing bars properly???
There are many ways to correct the body roll. Just depends on what way you want to go.
Hahaha. Maybe the wife is right, if I can't even explain "car stuff" properly, anymore.
Have seen several that have bent the sway bar brackets that attach to the lower frame rail. Pic compliments of akarilo, a local so similar terrain.
Plus, the sway bar arms are too low, and if the damage I've experienced in the FJC is indicative of terrain/driving "style" (hahaha) it won't be long before they're destroyed, too.
TheBigBoy said:
Old Man Emu Nitro Charger sport shocks. L=longer
Fronts
http://www.trdparts4u.com/scripts/prodView.asp?idproduct=-6249
Rears
http://www.trdparts4u.com/scripts/prodView.asp?idproduct=-6250
Temporary, as previously stayed, until travel variables determined, but I'm less than impressed with the ride with these. The ride feels harsh, but believe the valving is too soft.
I'm hope not indicative of 80 series ride quality, overall, but if it's is I'll fit triple bypasses, should need be.
I realize a heavy wagon and I'm being picky, but I live in OK where the best roads are a grade above washboards, want to keep my kidneys, and DON'T want to hear my wife constantly complain about how rough the ride is.
Flame on.
I'm going to fab a drop bracket, depicted above, and mount the rear sway again (I couldn't mount without major binding once coils were in) and butt dyno (drive it around) to see if it "feels" much better, with only a rear.
There's no hope of doing the same for the front, without spending cash on drops, and I'd never run the OE front sway bar oriented as it was, anyway. Already bent the front drive shaft with the sway, before I even drove it.
Short answer. Gonna put the rear on to see if I like.
Talking to a buddy with an uber built FJC that is proficient in the engineering aspect of suspension design, about assisting in sizing a rear bar, based on all pertinent aspects.
Would like to calculate it with only a rear, then a front and rear just to see what results.
The rear won't be much of an issue, especially if I can redo the e brake and be rid of the crap on the back of the axle.
Pics of Green73's mock up.
Here's thread.
https://forum.ih8mud.com/80-series-tech/553599-rear-sway-bar.html
Which is surprisingly similar to the one I've already done. Considering the 4 link and frame dimensions of the 80 are very similar to the FJC, once the bar diameter can be determined, should be good to go.
The front poses many other challenges, and the OE will minimize the Superflex's arms to articulate, so if I can fit a bar, great. If not, hoping the rear will correct.
I'm interested in input regarding. This topic has been beat to death, and tiresome of the "don't be a putty, pull the sway" argument.
Intend to load my family in an overweight elevated pig, and drive at 70-80mph, plus there's benefit to body roll mitigation off road, as well.
Since I'm past the point of coil overs and don't intend on, anyway, I don't have a clue how it's possible without some form of anti sway bar.
Interesting build and I can see why one wants to free the front en up, but this build and the statement above is just at odd with each other. :)
Story of my life, but have to have aspirations. Otherwise, what's the point.
There's no feasible way I can conceive a anti rock bar for the front, without 2.5" more axle width, minimum, or attaching to the radius arms, which is merely an out of left field statement. I doubt feasible and have no basis for which to state a good, or bad idea.
Will continue to explore the options for the rear and correction in some form of shock valving if that doesn't suffice.
This is not a replacement for your sway bar but is certainly a great tool for stiffening up your front end for on road driveing.
http://www.rancho.com.au/rancho-rs9000xl-shock-absorbers.html
I have the Tough Dog adjustables on my 80 (dont know if they are available in the US).
On road i have them quite stiff which allows me to corner quite hard and minimise body roll.
I have used with and without the sway bar. It does sit flatter with the swaybar attached (and I too drive around with my kids so i like my swaybars attached for safety on road) but you can stiffen the shocks up when not running swaybars to minimise roll when entering corners.
The is the in cab controller so you dont have to crawl around under your vehicle.
https://forum.ih8mud.com/40-55-seri...hock-air-controller-install-review-picts.html
IF I were to run no sway bar up front, this is definatly the setup i would run - exellent offroad flex and a good comprimise for reasonable on road handling.
Without the sway bar and my adjusters stiffened up, It tends to understeer abit, so I believe a part time kit would also help in that area.
Sway bar extensions are just a part of lifting suspension. http://www.suspensionstuff.com.au/shop/product_info.php?cPath=26_51_120&products_id=315
Stronger than stock.
You wont have to run a front sway bar. But you can if you like. Its all upto you at the end of the day.
But I think the antirock rear sway bar is a total waste of time. Its not very good on road nor offroad. Its just in between. The main thing you want the rear to do is control the body roll. Not all but most of it for road use. If your not happy with the stock rear sway bar, upgrade to the whiteline heavy duty and then just disconnect when offroad. The other path is to re do your link numbers and geometry as I have.
The biggest question to ask yourself is... You want it good on road or offroad.
May be a classic case of MY alligator mouth and a tadpole ass, but remains to be seen.
Opted for components halfway around the world, so I took it serious from the onset.
We'll see.
Only adjustable I know of that are pin-pin capable are King's, but don't know of anyone running on an 80.
I believe the King IBP's were determine useless in anything less than a 14" shock, and only guy that I know, that would know is Jowett, and haven't seen him around in awhile.
External bypasses appear possible, but overkill for "on road" ride quality, but not compromising comes at a price.
Not familiar with the whiteline heavy duty. What makes it disconnectable where the the stock one isn't, because it just hangs down there.
Nice thing with the anti-rock is you can put your links at different possitions on the arms to tune it for street or dirt, or disconnect the whole thing.
The whiteline is just a thicker sway bar. 30mm thick vs stock (rear). I dont run a front sway bar.
It really does control the body roll well. But Im not a fan of how low the middle sits. So cutting and reworking mine.
The disconnects are on the extensions.
Pull a pin and your sway bar is disconnected. There are lots of different styles out there. Do a search.
This gives you great onroad and the best off road with a 10 second mod. I can understand a light sway bar for offroad/off camber sections. But thats with a full linked truck. Not a 80 with radius arms.
