Im Running the superior Flex arms in my 4" lifted 80.
The front sway bar bolts straight back in - onto the top of the superior arm on the LH side (drivers side for the yanks) and the RH side has an extension that just bolts in to the original mount.
You have to cut the origional LH sway bar mount off. Very easy for an engineer to replace if you wanted to go back to original.
There are lowering brackets for the rear mounts of the front swaybar that you order, according the the height of lift you are running.
Instead of useing bolts on the front swaybar mounts, i made up some pins with a R clip. I also welded 2 mounts to the chassis, so when i pull the pins i can swing the swaybar up to the chassis and locate there. You could just use some zip ties or bungee or whatever to hang the swaybar off.
Road manners are exellent. When i got the wheel alignment done after fitting, he only had to adjust camber.
Flex - they work very well once sway bar is removed. I dont have any measurements, i can only say they flex much better than standard.
Straight forward bolt in mod, easier than mucking around with offset bushes.
I cant get any pics up - i think my quota is full - but you can check out pics of my rig on the 37" tires thread on here.
I hope this helps.
