And while googling radius arms, I found this thread, which appears to be from the designer of the SE arms themselves...
Offroad 80's • View topic - SuperFlex radius arms for cruisers - at last!
for some reason that page starts to load and then blanks out on me.
I got this much though
Test criteria: Stock 80 series w/ HD 3" lift open diffs, sway bars and OME shocks.
Test regime: Performed on a 30deree ramp with front shocks removed to allow comparative measurements across the front shock mounting surfaces.
Tests performed:
1- Swaybars attached F&R, STD radius arm configuration
2- Front swaybar disconnected, rear swaybar connected, STD radius arm configuration
3- Front swaybar disconnected, rear swaybar connected, STD radius arm configuration with front bolt removed on Passenger side (to simulate 3link/X-link max flex)
4- Front swaybar disconnected, rear swaybar connected, New SuperiorEngeering Superflex radius arm installed.
5- RTI calculation – (configuration as per #4) 30 degree ramp driven forward and reverse directions.
COMPRESSED EXTENDED TRAVEL DIFFERENTIAL NOTES
TEST 1 543 640 97 3" STD + SWAYBARS F&R
TEST 2 505 660 155 3" STD + SWAYBAR REAR
TEST 3 475 770 295 3" BOLT REMOVED + SWAYBAR REAR
TEST 4 490 725 235 3" SUPERFLEX + SWAYBAR REAR
Note: OME shocks to suit specified lift = 710mm ext, 480mm comp, 230mm travel.
TEST 5 – RTI as calculated, 2850mm wheelbase. (config #4) Superflex arm fitted, rear swaybar connected.
Distance travelled FORWARD - 1795mm = 909 RTI @ 20degree (622 RTI @ 30degree)
Distance travelled REVERSE - 1690mm
Supplementary Testing:
A further set of tests were performed in which to acquire data for the optimisation &/or replacement of shocks and springs to create ‘a full package’. The testing involved removing front and rear shocks so as not to pollute the data and allow access to measure the available travel of both front and rear suspensions, this also allows us to measure the useful travel of the vehicle setup as a whole.
Results:
TEST – FRONT TRAVEL 485 730 245 3" SUPERFLEX w/ SWAYBARS REMOVED FRONT & REAR
TEST - REAR TRAVEL 440 740 300 3" SUPERFLEX w/ SWAYBARS REMOVED FRONT & REAR
RTI – (distance as measured on 30 degree ramp)
Forward – 1830mm = 940 RTI @ 20degree (642 RTI @ 30degree)
Reverse – 2065mm
Conclusions:
Overall flex direct comparisons (test#2 – test#4) show a huge improvement in front end flex, with useable travel increasing from 155mm to 235mm+ as measured at the shock position. This amount of flex (230mm+) is equal to or greater than the maximum shock travel as offered by most OE manufacturers. Test #5 was performed as an indicator of overall component integration, and the maximum constraints of standard suspension components. Continued testing and development is recommended to attain the better commercially available shock and spring alternatives. So for the first time a good bolt-in solution is offered that can finally use ALL of the available shock travel in most ‘long-travel’ lift kits!
