i got them and you cant run a front sway bar with the and you dont need it anyway they are great
you have any more pictures? need some action shots.
None of us know the exact design limitations because none of us were on the Toyota LC design team in mid-to-late 80's when the front radius arms were designed and implemented into the 80 series, then the 7x series vehicles. ...
... You can only do so much and still have a modicum of "drive-ability" with these rigs.
The "what the Toyota gods intended" argument doesn't hold water. My guess is they didn't design the rig to have heavy bumpers or sliders or lifts or big tires or most any of the mods that are commonly done. The "mid-to-late 80's" may have been the pinnacle of design or not, but the fact is, a lot has changed since then. both in auto design and off-road.
I agree that the '80 will never be a great rock crawler, too big & heavy, no amount of sawzall will fix that. But it does amazingly well,, for a bus.![]()
A stock rig can flex to the full limit of the shocks, travel/flex is pretty much "balanced" front and rear. My guess is this is "what the Toyota gods intended". When lifted the front becomes much stiffer than the rear, so messing up "what the Toyota gods intended"? The goal of an off-road rig is to keep the tires on the ground, maintain as even as possible ground pressure/traction between tires in uneven terrain, a stiff front end is counterproductive to that basic goal.
Everything is a compromise, agree that the '80 is a top heavy bus, so floppy jalopy would be bad, especially on a street driven rig. Suspension change doesn't instantly equal floppy jalopy, it can be made as soft or stiff as the designer wishes. Softening the front flex spring rate to be closer to the rear makes a dramatic improvement, the rig lifts tires less, maintains traction more, bounces around less, is easier on rig and passengers. Anyone who is even slightly familiar with the '80 would notice the improvement immediately on the first trail ride. My wife did and she knows little/nothing about cars.![]()
Finally, some one that knows what they are talking about, thanks. I've been designing and building suspension for 5 years. The only thing I've seen that inhabits a 3link from driving extremely well on the road is the guy building it, most often its the same guy choosing the springs and the shock setup, deciding if he/she wants an anti sway bar or not.
There are way to many people that copy each other from one build to the next, using the same design type of "I put the link there cause it fit, and I saw John Doe do it too". There are not nearly enough people researching and finding the problem as to why it doesn’t drive like it should.
Its not often you see someone take a suspension from its conception and tweak it over the years and continue reporting about it to find what worked. More often than not, the write up includes ones initial install and typically that’s all we see or hear about. The fine-tuning of a system is so import and most people really don’t do that. If you've only built one or two suspensions and you've never tuned a shock or changed the length on a anti-sway bar then there is a good chance that its not right, at least not yet. No one can be expected to get it right the first time.
All I'm saying is generalizing a radius arm or 3link setup and not looking at the attributes of the two on the comparing vehicles is presumptuous.
No, I’m not an engineer, I’ve learned much from trail and error, and I have two close friends that are engineers in the field of vehicle dynamics and I speak with them all the time. So forgive me if I don’t have the engineer speak you’d expect if I’m arguing these points.
Cool. Show us the 3-link on the 80 that drives like it should.
Not happening. At least not without an R&D budget like Toyota's.
I have every intention to.
That wasn't a flippant remark I made, despite the welcoming ************
Virtually everybody who has 3-linked the front of an 80 has stated that road manners declined significantly. Having been around suspension conversions for the last 12 years, I think the challenge is dealing with the rear suspension, not the dynamics of the front.
It is relatively easy to convert a front coil suspension to pretty much whatever you want, but rear coil spring dynamics are far more difficult to address when they were designed specifically with the (rigidity of the) front suspension in mind.
Let us know what you come up with.
performance aside, could they have made that arm more retarded and fugly looking?![]()
Im excited to see what you come up with. You leaning toward triangulation of the rear? I sure would love to ditch my panhard back there. Also, whats the advantage to a 3 link front with a 4 link rear, as opposed to 4 link front and rear?
Thank you, and I agree with you on the rear, I should have been more specific. My intention it to produce a kit that address the entire suspension of the vehicle, not just a simple lift. If that means the gas tank gets relocated or one has to purchase an aftermarket one designed specifically for certain link placement, then so be it, if in the end both front and rear work in conjunction with each other as they should then great. I have no intentions of producing a "good enough" system.
BS, type of suspension (1, 3 or 4 link, radius arm, etc) is irrelevant, it is all about roll/flex spring rate, any type can be designed as stiff or free as desired. The stock rig flexes relatively equally front and rear. When lifted the rear is largely unaffected, the front becomes much stiffer, screwing up that Toyota design work.
Look at the pic of the black rig. Depending on lift height, the front becomes very stiff. The rear does all of the flexing, once fully flexed, the front is forced to flex, maybe. In this case the right rear is off of the ground, left rear is on the stop, the left front has reduced/little ground pressure, if it were climbing instead of descending, would need to be locked. Due to the huge difference in ground pressure among the tires, it is much more prone to, slipping, loosing traction.
Now the white rig, mine. None of the corners are on the stops, it flexes more evenly, without being forced, like a stock rig would. When in the same spot as the black rig it doesn't lift a tire. Because of right front compressing (front flexing properly), the right side of the rig is lower, more level, doesn't lean into the rock as bad and maintains traction much better. If it were climbing, would do it unlocked.
If you have never driven an '80 with the front softened to be closer to the rear, you have no clue what you are missing. On a normal lifted rig, the front dominates, a front tire drops into a hole and the body goes with it, slamming the occupants side to side. The body movement is weight transfer, attempting to jerk the tires around, the tires are more unevenly loaded (uneven ground pressure) so, much more likely to loose traction, slip. When the front moves how it was designed to, there is much less body movement (weight transfer), ground pressure is more even, increasing traction and is much more comfortable for the occupants.
Can't post all that info up and not tell us what you're running!![]()
