Superflex radius arms
I think the best set-up by far for both on and offroad is the Rubicon Express long arm kit as seen here https://forum.ih8mud.com/80-series-tech/294260-jodo-97-lx450-coilover-project.html
X4 - I see it as the greatest bennifit for the least risk and the least $$$. If you built your own arms, it's at least as cheap as a 3 link, so a home made 3-link being cheap argument doesn't hold water.
But we have all seen the possible weaknesses of a 3 ton vehicle on a 4 link, as well as a 3 ton vehicle with a 3 link. Anyone who tries to argue that the suspension and design of a 3 link are within factory design specs. is fooling themselves.
In all truth, taking a 4 link 3 truck and driving it like a car is foolish; anyone trying to do this with a 3 link is even more deluded.
So, all those Dodge rams with 4 link (5 w/ panhard), and Superduties, those are all bad 3 ton vehicles? I've said before, if someone really wants to run a 3 or 4 link, I'd spend some time looking at the supeduty kits.
Virtually everybody who has 3-linked the front of an 80 has stated that road manners declined significantly. Having been around suspension conversions for the last 12 years, I think the challenge is dealing with the rear suspension, not the dynamics of the front.
They especially handle like crap when you leave bolts out. I don't think this is indicative of the 3 or 4 link, I think it has more to do with how these people came up with the design. I haven't seen one that will share the calculations they did - and I believe that is mostly because they didn't do any. "oh, well, we copied what was done on a cherokee and didn't adjust it for the fact that this is a bigger truck w/ a looser rear".
BS, type of suspension (1, 3 or 4 link, radius arm, etc) is irrelevant, it is all about roll/flex spring rate, any type can be designed as stiff or free as desired. The stock rig flexes relatively equally front and rear. When lifted the rear is largely unaffected, the front becomes much stiffer, screwing up that Toyota design work.
Look at the pic of the black rig. Depending on lift height, the front becomes very stiff. The rear does all of the flexing, once fully flexed, the front is forced to flex, maybe. In this case the right rear is off of the ground, left rear is on the stop, the left front has reduced/little ground pressure, if it were climbing instead of descending, would need to be locked. Due to the huge difference in ground pressure among the tires, it is much more prone to, slipping, loosing traction.
Now the white rig, mine. None of the corners are on the stops, it flexes more evenly, without being forced, like a stock rig would. When in the same spot as the black rig it doesn't lift a tire. Because of right front compressing (front flexing properly), the right side of the rig is lower, more level, doesn't lean into the rock as bad and maintains traction much better. If it were climbing, would do it unlocked.
If you have never driven an '80 with the front softened to be closer to the rear, you have no clue what you are missing. On a normal lifted rig, the front dominates, a front tire drops into a hole and the body goes with it, slamming the occupants side to side. The body movement is weight transfer, attempting to jerk the tires around, the tires are more unevenly loaded (uneven ground pressure) so, much more likely to loose traction, slip. When the front moves how it was designed to, there is much less body movement (weight transfer), ground pressure is more even, increasing traction and is much more comfortable for the occupants.
I agree Tools. Every time someone bashes a 3 or 4 link, they call it floppy jalopy. That's cause you rarely (ever?) see one that has the effort put into it to tune the swaybars and shocks, and springs to work as a system.
I also agree with how the front pulls the truck down. I think this is likely worse when you are running realy long shocks like I am cause there is so much further for the rear to go before lifting. My biggest issue, and others have stated the same, is coming down off 2-3 ft ledges one wheel at a time, rather than the front flexing and allowing that first wheel to drop, the whole body goes and the opposit rear come up. Same thing as in your photos but a bit more dramatic (read scarey) when it's a ledge you're coming down.
Stock the suspension doesn't have that long of travel shock, and the radius arms are laying flat, so you really don't get into the binding that you do when it's lifted. Run 3-5" of lift w/o dropping the radius arm mounts you start driving more binding. Run longer travel shocks, you add more binding. Expecting the front that is running at angles it was never ment to run at, and at levels of articualtion that it was never intended to to magically "balance" the rear is bad logic.
They especially handle like **** when you leave bolts out. I don't think this is indicative of the 3 or 4 link, I think it has more to do with how these people came up with the design. I haven't seen one that will share the calculations they did - and I believe that is mostly because they didn't do any. "oh, well, we copied what was done on a cherokee and didn't adjust it for the fact that this is a bigger truck w/ a looser rear".
Walking Eagle, you made my point exactly, its the definition of insanity; doing the samething over and over, but expecting a different result.
Question for you all
Since at the moment I dont own a 80, can you guys tell me again please, while in low range with longer shocks does the vehicle raise or sink when bound up against something. If you were in low,low and kept the engine running at 1000rpm with your foot on the brake, would it raise or sink? And do you have lift on your vehicle? If so how much?
For someone who is getting ready to lift their 80, this thread sure gets confusing. Initial plans were the FOR lift with 35's. I'd like as much flex out of the front as possible, but I am not well versed enough in suspension design to even attempt to make my own arms.
Road handling it of utmost importance as I have to actually get to the trail first safely with my family. I'd be willing to drop the coin on the Superflex Arms if they truly make that much of a difference.
Personally, I would go for those Superflex arms. They look great and the video shows the stock swaybar mounts so you are stable on-road.
That is some really good flex off the front end and the arms certainly look like quality parts.
It's all bolt-on, considering what it gives you, is a no brainer. It's just pricey, otherwise I would be ordering up a set.:meh:
I dont believe it is, I think it just brings to light the fact that other design types can be extremely good if the person building it is willing to go beyond what most do. Ya, cant just stop at "I put it on, why doesn't it work?" There are to many varibles, most of which go untouched by novice builders. Heck it took me 4 tries to find the link geometry that I think works. Now it's great on and offroad. Yes I know, "but you drive a 85' 4Runner not a FZJ80". That doesnt matter, there is no reason a 3 Ton vehicle cant also drive well down the road and offroad.
I've learned over the years that building a flexible suspension that performs well on-road and off share alot of design features. Many people think, you either have one or the other, thats simple not true. The better mine performed on, the better it did off-road too.
Again to simply say a Radius arm performs better than a 3link is foolish. There is so much more to a suspesion than just link geometry. Again this all goes back to the builder.
Ya, but they're so darn big. Look at how low to the ground they are. Thats a huge anchor.
I am just observing what I have seen. Every 3-link owner I can remember posting has commented that road manners declined.
This is not about front geometry, IMO, but how even a perfectly designed 3-link will interact with the stock rear suspension. The correct geometry for 3-linking a Cherokee is going to be the correct geometry for 3-linking a 80. The difference is the Cherokee is designed for the load/bearing and stability in the rear suspension and has a stock 4-link, and the 80 is designed for that stability in the front suspension, which is what is being modified on the 80.
Having spent years with Cherokees, watching that group of owners go through these exact same discussions, and well as watching the attempts to convert the rear leafs to a coil/link suspension, the front to radius long arms, and on and on, I know how difficult this is to get right. Which is why I enjoy watching 80 series owners believe it will be different for them.
Everything we do is increasing offroad bias and decreasing road manners. That is the nature of the beast in our sport, it is only a question of how far you take it. I spent $25K learning that lesson on a Cherokee, and in doing so made it a less excellent dual purpose rig. I leave my 80's suspension alone purely to avoid repeating history - with four kids I don't have the time or money. If I was a young single guy, I guarantee you I'd have re-engineered the suspension a long time ago, except that if I was a young single guy I wouldn't wheel this 3-ton ocean of metal and glass.
It is good to see this - you don't need an R&D budget, there are spreadsheets around that give you your exact calculations, and they have been around for years. As to whether you like the results is the only question, because they are never neutral.
As evidenced by the classifieds, most 80 owners don't like the results, because pretty much every one has been put up for sale. Or more to the point, this is just a stop of the road to a buggy, because no matter what you do to an 80's suspension, the rig doesn't get any smaller or lighter, the frame mounts don't get any higher, the gears don't get any lower, and those are far greater issues on this rig than the radius arms.
That pic Tools posted with the tire off the ground is a picture of a poorly designed spring/shock combo. My suspension has never done anything remotely like this, and I have relatively short shocks.
I still like these SE arms. They achieve what Tools has achieved, but you still have two bolts to the axle on each side. The Rubicon express arms have their downsides. If you guys had ever wheeled that arm, you would know what they are.
The driver side looks lower than stock by a little and that's about it.
Yes it can get caught up on rocks but it's moving w/ the axle and I don't think it would be a major issue considering what you are gaining.
If it catches, it catches. :meh: Winch or drag it over. They are certainly stout.
For a bolt-on solution, looks great to me.
If Fireguy wants to order it and let me "test" it for awhile, I'll be glad to help:steer:
You'll be happy with the FOR lift and 35's, the rest of this is just for those who want to take it to the next level, it's not for everyone.
Agreed - you should wheel it first, and see what you think. I have the FOR 3.5 suspension, stock front suspension. There is more to suspension than your link design. The FOR setup uses much higher end coils that the typical OME suspension you see, and lower valved shocks to go with them. The suspension is also designed for balance in up/down travel, which means you have max travel before running out at any corner, and it keeps the shocks at 10" so you aren't introducing a lot of travel that only the rear suspension can use.
I wheel with my front swaybar removed, but I never remove the rear swaybar. Take a look at this first video - it doesn't look like much, but this is a very steep washout that drops almost vertically on the passenger side at the bottom. I have seen a roll and a couple of near rolls on this spot - my suspension stays so level that you have to watch the front axle carefully to see how far it is dropping. Then watch the flex at the end. Do you see balance or a lack of it?
YouTube - Nay 11/6/2010
Here you can see both the pros and the cons of the 80 suspension - it climbs so easily with the rear doing the work, but I get some lean due to the stiffness of the front end - it also keeps the body off the rock - and then the rear climbs effortlessly. You can see I barely pick up a front tire at one point, but I never felt it.
I'd get the SE arms if I was unhappy with the comfort. Tools is right that occasionally you'll hit a rock with the front and really snap the passenger compartment, and that really is a PITA. 37s on 10 PSI help with this, but what keeps me away from the SE arms is lack of a front swaybar. I don't notice it just me driving, but fully family load I do want that swaybar. I'm sure a swaybar solution could be easily fabbed, but I'm curious to see how the SE arms work with caster plates, i.e. do they keep pinion angle identical to stock and work with modified mounts (caster plates)?
YouTube - 11-06-10 Old Chinaman Gulch-Nay-
This is not about front geometry, IMO, but how even a perfectly designed 3-link will interact with the stock rear suspension. The correct geometry for 3-linking a Cherokee is going to be the correct geometry for 3-linking a 80. The difference is the Cherokee is designed for the load/bearing and stability in the rear suspension, and the 80 is designed for that stability in the front suspension, which is what is being modified on the 80.
Like I said earlier, I know guys that are Professional Vehicle Dynamists. That being said, I've had these same discussions with them, you'd be really surprised to learn what they design these "OFF ROAD" suspensions for. Most are not designed as you think. Most are beefed up brackets and arms, which still bolt to the factory locations. Any time you lift a vehicle and keep the factory mount you aren't keeping the geometry. Even with the LONG ARM designs they aren't keeping anything close to stock geometry.
The purpose of lifting a vehicle is only to acquire larger tires and allow more movement. What should be done and isn't, is design-build a suspension that mimics the stock statistical data while providing lift. Which never happens because large companies are price conscious. They are looking to sell parts and selling someone on a kit that is two or three times more expensive than your competitor’s is difficult to do at best. When it is done, it’s a giant drop bracket, which acts like a rock anchor. This is the penny pinchers way.
Nay, with all do respect I completely disagree with your theory when you say, "everything we do to perform better off road is going to make our on road driving worse. To a point yes, there is no getting around the fact that your COG is higher and larger tires that increase un-sprung weight don’t help either. The vehicle will always lean more in a turn because of the COG and because we are allowing it too by softening the springs and lengthening the shocks, but if it’s a controlled lean and isn’t scary then in my eye’s its acceptable. If in the end it reliable, predictable, drives in a straight line and doesn’t wander but still flexes as expected then you’ve done your job. This is not impossible, as I stated earlier, start from scratch and think out side the box you can build a great suspension that performs extremely well in all conditions.
And how many 3 - link owners have changed swaybars? Messed around w/ swaybar rates? Shock rates? Spring rates? How many have changed the frame emounting points? Last one I looked at just reused the stock mounting points. What are the chances that the stock radius arm mounts are in the pefect spot for the perfect length 3-link? Slim? None? 3-links for taco's seem to work pretty good from what I've read.
Well, that's the DUH statement of the year. Unfortunately, there are people out there 3 - linking not giving any consideration to balance between the front and rear. It's not the 1st or last time I'll speak of balance when these topics come up. I'm very Zen that way.
I think you're missing a NOT in there - as in the correct geometry for a Cherokee is NOT correct for an 80.
You're joking right? Please tell me this is poor sarcasism - cause if you really think all that's needed is to dump a few #'s in a spreadsheet.... welll.... then I'm not gonna continue to discuss as there is little reason in it.
Or you could share. Let's remember why Jeeps, both styles of cherokee and the wrangler go to radius arms in a bunch of suspension systems to begin with. There isn't room for a proper length 5 link w/ correct angles once you go beyond a certain point, unless you drop some mounting points.
I see a lack of it. The front is pulling the body down and forcing the rear end to unload. If it was a really big steep drop you'd see it even more.
What keeps you away from reading any of the half dozen posts in this thread or listening to the video saying it keeps the swaybar? It's one thing not to know, it's a different thing to have been told over and over and still state incorect information.
Back to the origonal point - Superflex Radius arms
Advantages -
Bolt on
Improved flex
Still have two mounting points so should keep axle from diving as much as Tools arms - not that his is excessive, but I belive he has said it's more than stock
Should not be nearly as floppy as a 3-linik
Disadvantages
Nay will keep telling you that you have no front swaybar :)
Couldn't you just build off of these on the arms currently on the truck.
For instance you could copy the design with the slee gen II arms on my truck so they wouldn't be anchors.
