Superflex radius arms
Not sure if this has been discussed elsewhere in this thread, but updating while I'm thinking about it.
The SE's will require a longer front drive-shaft and, in my case, a DC shaft (loaner DC currently installed and works flawlessly).
Issue is, the typical Taco shaft is too short by an ~1 1/2" once modified, so a built shaft (at the very least, sectioning a DC into the OE) will be a necessary.
At RH, I've 32.75" tight between flanges, where as most are ~31.5".
They're well built, stout enough to take abuse in the rocks, perform well.......but running a temp shock that bottoms out well before what the arms are capable of.
Since a recent tire change has now prompted fender cutting, which needs to occur before cycling to spec shock lengths to Radflo, it'll be a bit before I can depict the capabilities.
So you do need a longer drive shaft to run these arms?
Yes.
If no intention of running PT, need a double, double cardan.
I have no intentions of running a PT set up, so longer, DC shaft then. Pricey, but a much simpler answer to more flex up front than linking...
New, as in no need for new front drive shaft?
The early superflex arms where spaced forward 20mm for nearly all lift sizes. The later version is not, and on a sliding scale (as it should be). There is no need for a new front shaft per say. A shaft spacer is fine. The reason you need a new shaft is to eliminate the vibrations caused by the truck lift (Greater uni angles). So you wil need 1 with any decent lift.
I'm running old ironman medium front springs with a 12k winch front, so right around 2" of lift.
Well that 20mm spacing is likely why Delancy couldn't get his truck to run smooth with a standard DC shaft. That would be giving the engineer the benefit of the doubt that he dialed in caster correctly. Either way I told you they were poorly designed.
And at 4" of lift and properly adjusted for caster a stock shaft will not run clean. It's not because the rear joint angle increased but because the front joint has decreased to the point of having no angle. That's the reason for needing a DC shaft.
But we've covered this a few times and you keep coming back to having a part time truck. Why should anyone have to sacrifice Hi range AWD operation when there should be no need to. Just design the arms correctly.
That is good to know. Is there any arms on the market that are a "perfect" design. Just for future reference. What would happen if these superflex arms where pared with MAF drop brackets? Would that relieve the need for a dc shaft?
Gibson, as in the guitar manufacturer, spent a lot of time designing arms that were "perfect", but they're not purchasable.
Drop brackets with SE arms will not negate the need for a DC shaft with 4" of lift, regardless the opinion that the DC shaft is a band aid.
Best way to "do it right" is cut and turn the axle, be it OE or aftermarket housing.
Not this again! I've asked Chris to measure the distance between the bolt holes of his SF and his stock. If its the later arm. It won't be 20mm. You keep saying poorly designed arm. But you would Never have been smart enough to design them. Caster on all the SF arms is spot on. There is no problem with the SF arm, only it doesn't work with land tanks dc shaft system.
Again... I chose part time, as I have on all my trucks. Instead of playing games with DC shafts - Fix the problem angles by modifying the housing. JMHO
it's nice that you would credit me with designing DC shafts but that is simply not true. I didn't desgn them only use them appropriately.
Output flange to output flange, precise measurements used for Hi Angle shaft.
33 5/16" top
32 11/16" bottom
33" center
Those are a solid inch further away than stock. So if the arms do correct for caster properly then the diff flange is pointing out in front of the t-case flange which would introduce some angle to the front u-joint that otherwise would not be there. That's why neither typical drive shaft will run clean on your truck. Too far out for a stock shaft but not close enough for a DC one.
With the announcement that the arms are being redesigned and shortened it would seem they figured that out.
