Supercharger Removal
What about an air bag between the body and manifold?
You can apply slight pressure and should be able to create enough of a gap to get a razor in there.
You can try the same technique as mentioned before in this location. Instead of a bolt going through and expanding the joint with a nut, you will need a stud/bolt that is about the opening with and a nut, preferably a coupling nut (they are longer), to achieve same result. Again, use some sort of backing to protect the surfaces.
Deflate a basketball or a volleyball and jam it in there. Inflate it and I’ll bet that’s the ticket. 🤔 there’s your airbag.
I'm ashamed to admit, but the method that worked came from Google search AI. :shame:
Step 1: heat above 140*F. I used a MAPP torch, as @Irish Reiver suggested, held 8-10" away to try to prevent any further powdercoat damage.
Step 2: tap in two utility knife blades. Straight razor blades did not cooperate. I did the one in the front first, merely because that's where I found the first gap, and then the one in the rear. Apply more heat through this step.
Step 3: tap in a plastic wedge. The utility blades create enough of a gap to get this started. Keep driving it until the halves separate.
Success!
Sidebar: I need a catch can.
Sincere thanks to all who helped with their suggestions and ideas!
All that for this. :rolleyes:
Totally unnecessary, to boot. The o-rings looked new. I easily pulled the stub with a water pump pliers and replaced it with a brand new one.
Glad you managed to get this off. Now jump to step 6 because as the man said, "it's a reward". :flipoff2:
