Yes. The upper one is what you would plug the intake with if you were not going to add a Boost gauge (B/G).
The lower one is the adapter you use for an aftermarket B/G. It appears to be 3/8" male/female.
I just ordered some brass fittings that I believe will work to attach a 1/8" plastic hard line from the B/G.
I am going to try a 1/8" compression-1/8"male fitting and a 1/8"female-3/8"male bushing to attach the plastic line to the TRD adapter.
I'll post my results when the parts arrive.
I ordered from
Fittings and Nipples
[FONT=Arial, Helvetica, sans-serif]18001[/FONT]
[FONT=Arial, Helvetica, sans-serif]1/8 COMPRESSION SLEEVE[/FONT]
[FONT=Arial, Helvetica, sans-serif]3[/FONT]
[FONT=Arial, Helvetica, sans-serif]$0.39[/FONT]
[FONT=Arial, Helvetica, sans-serif]18176[/FONT]
[FONT=Arial, Helvetica, sans-serif]1/8 X 1/8 COMP X MIP ADPT[/FONT]
[FONT=Arial, Helvetica, sans-serif]1[/FONT]
[FONT=Arial, Helvetica, sans-serif]$1.28[/FONT]
[FONT=Arial, Helvetica, sans-serif]28103[/FONT]
[FONT=Arial, Helvetica, sans-serif]3/8MIP X 1/8FIP BS BUSHING[/FONT]
[FONT=Arial, Helvetica, sans-serif]$0.9[/FONT]
