Super Charger Boost Input
I don't think the boost line sticking into the manifold is that critical, and I don't recall that instruction on any guage I've installed.
WRT dimming, probably your best convenient bet is to tap into either the light for the cigarette lighter or the ashtray, as those are easy to get to.
The good thing about the boost guage, is you can notice differences in tip in throttle vs SC response. You whack your foot to the floor, the SC tends to ramp less quickly than if you ease in, then pedal down....
With such a stray from your original post, glad to see in the end, it all worked out for you.
Cheers
Scott J
Thanks Scott.
WRT the dimming. So would I just cut the cig lighter or ash tray line and splice in both the positive and the negative leads to the light or ground the negative and splice in the positive. Please excuse my electrical ignorance.
X2 on being able to watch the S/C ramp up smoothly and maximize power by watching the boost gauge. I noticed that you can really maximize the boost by controlling the throttle in relation to what the boost gauge was reading.
Thanks Scott.
Worst case you can use a scotchclip, normally my antichrist in eletrical, but this is not a critical circuit. Using either of the locations I suggested shouldn't cost you more than a 6pack of good beer to get done by someone more familiar.
Been a while since we've seen a 'new' install, and Im' guessing this is one of the latest kits. Do take pics!
Cheers
Scott J
94 FZJ80 Supercharged
from what I remember with SC
8.6 with stock MAF
10.8 with my MAF
I don't remember anyone checking a stock system.
Thanks Rick ..
Hijack ..
did you think that could be a cause of cracket pistion due to a AFR too rich ..?
Did you or anyone here have the specs of a 1FZ forged piston .. ( JE or Ross )
hijack over ..
Thanks Rick ..
Hijack ..
hijack over ..
I always thought piston damage was due to a lean condition resulting in detonation. One thing to remember that even with a wide band AFR meter it is still an average of all 6 cylinders. So you could have an injector problem on one cylinder causing a lean condition but is being masked by the other 5 cylinders.
a factory FZJ80 with only mod as a turbo, can compensate with factory injectors, ECU etc ..more air in the intake plenum .?
I've read here in some place that a WOT 1FZ NA archive around 10.8 - 11:1 AFR .. that enought to keep the things workining right and cool inside the engine ?
And if you said with factory MAF the 1FZ goes down to 8.6 ( that seems to be to rich ) at 6 PSI .. what does that mean for the internals of the 1FZ .. ?
From the results of testing the 95~97 factory injectors and ECU can handle more air from a turbo.
From what I've read even though 10.8 is still considered rich it is a safe AFR for protecting the internals of our engines.
Other than the catalytic converters I'm not sure what other parts would be harmed from running that rich at WOT
Cheers
Scott J
I will take some pics. It seems to be the same kit as the old one. I don't have a 97LX wiring diagram so that is what is holding me back.
But I am willing to do a complete write up that shows step by step instructions including which wires to splice etc with pics and links to vendors if someone could post the color codes of which wires to splice.
Posts #6 & #11 of this thread should explain it pretty easily. You attach one of the wires from the gauge to the green wire at the rheostat and the other goes to the green/white wire. If the gauge is backlit with a regular bulb it doesn't matter which wire goes where; if its an LED you may have to try it first to make sure the current is flowing the right direction.
Thanks I'll give this a shot. I might not have time to do this for a couple of weeks. I'll be sure to post when I do. I'll probably start a new thread and compile my tranny temp gauge and boost gauge together.
thanks for your answers Rick .. apreciated ..
Could I ask .. for the other scenario, what about if you are running much more boost, and go lean, means sure heat produced in the engine ..
Wich it's the max boost setting that the stock ECU, fuel pump, injectors etc .. can handle .. ?
I tried this and everything seems to be working perfectly. Just splice the wires from back light to the green wires and leave the black/white wire from the rheostat alone.
A good factory pump and injectors on 95 - 97 will handle up to about 8 psi boost relaibly, but any more and injectors will go to full duty cycle often, where they become unrelaiable.
The injectors will handle higher pressure, and we use Bosch 0414 in tank pump and malpassi adjustable rising rate fuel regs so 40-45 psi up to 70 psi + with standard injectors and 10 - 12 psi boost.
pre 95, extra injectors and better pump, or better injectors as well are normally required for that sort of boost/performance.
Im running up to 10.2 psi at 5500 rpm currently on my S/C 95 model, and we have been keeping around 11:1 A/F with the details above fitted and std injectors.
We are seeing 8's in PSi at around 5000 rpm.
We are using an aftermarket ECU to control ignition and injection.
Not sure. On the trucks that ran the stock MAF they saw AFRs of 8.6 at WOT nad with my MAF the AFRs dropped to 10.8. So that calculates to around 23% change. This was on trucks running in the 8psi range so it could be possible to go to 10psi and still have proper metering of fuel.
That is my target but I'm starting around 8 psi and then will work it up from there.
One important thing is that the US ECUs are not the same as others from around the world. So our experience might not equate to your's. I'd start at 8 and work up like I am planning and have a wide band at your side to watch things closely.
That appears to confirm my spreadsheets as well. Just using the knowns for the FZ engine, I'm showing about 27lb injector capacity required at 80% DC with 8psi at 5000rpm, not including any Density Ratio compensation (intercooler, etc). This should yield .86 lambda (12.6:1AFR) values easily.
It would appear to use the rule of thumb for a 1FZ, is anything over 8psi you need to address fueling variables (pressures, injectors, etc). Darren, why 11 AFR? IME with boosted motors, much below 12.3-12.6 the dyno shows no gain, and by 10-11 = losses.
Scott J
Scott J
Scott and around 8 PSI which should be the best AFR for an 1FZ engine .. ?
Lamda theory would dictate that peak power is at .86 lambda (12.6:1) and peak economy is at 1.05 lambda (15.4:1). Some dyno tests show that on high boosted engines, gains at lower A/F ratios. On an 8psi system, 12.6 would be fine. The bigger issue appears to be the ECU's ability to hold it there under WOT conditions. A WBEGO (wide band o2) can help you tune that on a dyno.
Cheers
Scott J
I am afraid I need a little more hand-holding on this question.
The tech @ the dealership put a port for a boost gauge @ the arrow. However this is pulling a vacuum @ idle and goes neutral under acceleration.
Does anybody have another pic showing where the boost can be tapped ?
