I have a 1995 80 and have experienced intermittent sunroof leaks, like I'm sure all have, but lately I'm about to go nuts trying to track down the latest and stop it. I have read every thread I can find on sunroofs and fixing leaks; I have cleaned the drains up top, cleaned the slits on the bottom, pulled the bottom drain plugs, and cleaned the channels around the sunroof, all to no avail.
So tonight while it's dumping rain I parked outside to see what happened and it's still leaking. Just on the passenger side and just in the right foot well where the drain plug is located under the wiring on the near the door. It appears to be leaking from sunroof, running along the rubber grommet on the door jam, and dumping into the footwell. When I pour water into the sunroof drains, I can remove the grab handle on the passenger side and lower the head liner ever so slightly and watch the water back up in the channel designed to stop water and spill onto the headliner, run toward the door, catch the rubber on the door will/jam, and go into the floor and pool on top of the drain.
I hope this all makes sense and someone can help me. If its vague, I can try to post some pictures of where the water is pooling and where its running along. I am desperate here, I'm sick of a wet passenger floor board.
