What up fellas!!!!
Cali finally got some real rain.
I'm trying to diagnose a little wetness on the front passenger side floor. I have read something about an AC hose down there below the glove box that sometimes leaks. I checked it out. Looks solid.
I opened up the sunroof and I can see the sunroof drain holes (2) near the front corners of the opened sunroof.
I will eventually run some weed whacker line down the drainage holes to make sure my lines are clean.
I have read that the drainage line goes down the A-pillar, but where does the line drain to?????
I took off the front passenger kick panel and there is some electrical and a black hose that runs along in there.
Is the black hose part of the sunroof drainage line???
I would also like to know if any of you tried anything different than weed whacker line to slide down those drainage holes.
Thanks fellas.
Thanks fellas.
