Stock spring flip rear
Costa Rica & Texas
After doing extensive research here and reading many post I can't seem to find any thought or photos on a rear stock spring flip other than those who installed OME 4" or equivalent. I would like to flip my rear springs to move the axle towards the rear for a more balanced look.
My current springs are military wrap on both ends. I did AAL (full length) to gain more heigh on both axles. I gained a little over 1". I recently posted a question for feed back on if I should AAL or extend shackles to gain more height. Decided on the AAL and am very pleased. It does ride a bit more rough (it is a 40 year old LC tho) and call me crazy but my LC runs much better. I can climb hills in 3rd were before it was 2nd gear only. The cruiser also handles corners WAY better. Suppose my old leafs were worn out. Planning a new leaf pack next year but this Will do.
Also plan on adding extended shackles in the rear to gain another 1" to balance out the stance. Currently running 32x10.50 wheels and clear fine. Just want that rear axle moved back to fill out the wheel well.
The photo was taken before the front AAL were added. Any concerns regarding the driveshaft? Other concerns I should consider? Anyone with photos please post so I can get an idea on what it may look like before I full the springs again. I know some say move the hangers but rather not cut and weld. Not lazy but would like a more simple alternative
You do realize that when the springs compress that the rear axle will move more to the rear? Reversing the springs could put you in dangerous territory possibly.
Drill a new hole in the spring perch on your axle and leave the springs alone. Still have plenty of clamping force when you do. This will keep it more realistic and no major modifications are necessary. I moved mine back about 1.5".
I don't think my perch are big enough for this option. I suppose I could move the perches an inch toward the rear and not mess with the springs?
Aside from a new drive shaft the drive line angles will change drastically thus affecting universal joint longevity and increasing drive vibrations and possibly other 3rd member issues.
looks like i will just live with it. no need to cause more problems.
Seriously, like others have said, drill 4 holes (2 in the spring perches and 2 in the u-bolt plates) and you can easily move your axle back 1-1.5 inches. It will center the tire in the wheel well. No drive line vibrations or anything like that will result. It's super easy to accomplish. Measure about 1 inch (or whatever measurement you want) forward on the spring perch. Drilling the hole on the front side will push the axle backwards. Drill it out big enough to fit the spring pin (sorry, I can't remember the diameter). Then, measure the same distance on your u-bolt plate and drill that out. Bolt it all back up, and now your axle sits about an inch farther back.
Here are some pics to help you visualize. This is 4Plus' U-bolt flip kit, but I did it to my stock u-bolts before switching to the 4Plus stuff. It's the same idea.
upload_-1
upload_-1
upload_-1
As pathetic as it is, this is the best side pic I currently have (on the way to the Rubicon last summer). For reference, those are 35x12.50's in the above picture. I did open up my wheel well a bit to the rear fit them. The 35's would have rubbed in front if I wouldn't have moved the axle back a little bit.
:cheers:
Thanks for the pics. Although i don't think my perches are big enough to drill new holes and and put the pin an inch back. I will measure tomorrow and see if it is possible.
Ok, I'm considering doing this but can anyone show me were they drilled the perch holes? Looking at my perches I don't have very much to play with so interested how some of you got 1.5" out of a stock perch???
Here is my perch.
i think you dont understand , it is not about the hanger on your pics that we are talking
I keep reading "drill holes in the spring perch"
I was under the impression this is the spring perch.
Ok, so that I am clear. I need to modify my spring plate by drilling a new hole let's say 1" from current hole.
Then I would need to modify the plate on the axle as well?
If so, there are only 2 holes per axle that need to be drilled?
Sorry for the confusion but when one says "spring perches" I think of the hangers and not the spring plate.
Yes, that is the correct location now, but 4 holes per axle.
2 holes per side:
- 2 for drivers side spring (axle perch & ubolt plate)
- 2 for pass side spring (axle perch & ubolt plate)
