As I'm driving I've noticed that my steering "sticks" a little after I've turned left and am returning back to center. Never happens when I turn to the right.
Any ideas?
Any ideas?
Did you ever find out the cause of the sticky spot ?
Machined? Or mechanically designed with that spring doodler thing on the side?The '80 steering box, like most, is machined to be tighter at center travel. If it is adjusted tighter than needed, can bind at that spot, If the box isn't centered to the steering wheel the bind spot will be off of center. That is the most common, but have also see worn housing/piston cause a bind, most often close to center where the most wear happens.
