Stellarbuilt 200 on 37s
Interestingly, the 300-series/TNGA-F architecture also moves the rear shocks outboard of the frame. Better motion ratio for suspension control. I imagine the frame there is clearance deeper for that config. Whereas here, the wheels move outboard making enough room for this config?
If you look closely, they notched the 200 frame.
I assumed they moved it outside of the frame simply to avoid dealing with the miserable stock upper mount (says someone that just installed rear Kings over the weekend). I would love to outboard my rear shocks after that ordeal :hillbilly:
Setting up bumps
Sweet! I've not seen that style of mount before. Looks way better than having to slit a can, weld it on, and hope it doesn't shrink too much.
How much travel is that bump?
Will the panhard rod ends stay in stock locations for final build?
Can't wait to see this thing completed.
