Steering wheel change
Corona, CA
Hey all. Finally driving my 80 after replacing/rebuilding almost all the mechanicals, now it's time to fix some of the minor things. I'm wanting to change the steering wheel. Would like a thicker grip and don't want to just do a wrap. I have a 1994 so no need to worry about an airbag. Are there any OEM steering wheels from other models that would work that have the thicker grip? I don't want one with a small center but I'm open to aftermarket. Thanks in advance!
I know you said no wraps, but I put on a wheelskins cover and love it.
Wild guess here :grinpimp: wheelskins.com
Pretty nice for a wrap. Beats my 7 dollar walmart variety
Frank at landcruiser heaven has an option too i believe
There are a few threads about options but ill refrain from suggesting a search so the anti suggest a search folks dont attack
Here are the results when you type steering wheel jnto the search box in upper right.
Search Results for Query: Steering wheel | IH8MUD Forum
I tried that and nothing showed up. Thank you for the link!
Not sure what your price range is, but my solution was to have an OEM wheel recovered to my specifications. It wasn't a cheap option and not for everyone, but the steering wheel is your main input device and it should feel good to you.
New steering wheel for the old LX
Now that's something I didn't even think of. I may do a search around me to see if there is someone. Or may have to get another wheel and send it off. Thank you.
I have used Wheelskins before and was pretty impressed with the quality and look especially when compared to the much more expensive options of reskinning or replacing the wheel. Good bang for the buck.
One of our club members had this done, really like the site. Toyota Steering Wheels and Wood Dashes - Craft Customs
Now remember to wash your hands after wrenching on the rig and going for a test drive. I reskinned mine in 2004/5 at texas custom steering wheels and feel my laziness has contributed to accelerated decline. Its in need again.
Cant recall the canadian former 80 owner here that did the is300 wheel in a black 80/450. Looked great and gave the cockpit a little modern update
Here it is LX450 OEM Steering Wheel Swap - Airbag Info?
And Franks website i mentioned above landcruiser heaven.
Land Cruiser Heaven Leather Steering Wheel Cover
IIRC up to 2014 at least gray knly was available new. ~$500 and just the wheel. Not the center airbag assy
Theres some convos about the ls400 option too.... not sure where they ended up.
Great info! Thanks!
I too have done the wheelskins deal. Works very well and looks much better than a cover. That said, for me it wiil soon be a recover job on the factory wheel because I do not care for the added thickness of the wheelskin (which isn't a lot really).
Is yours grey? Wanna trade? As long as it's a non airbag one
I just searched "Main Input Device" and "Should feel good" and never thought I would end up on a steering wheel thread.....carry on and delete your history.
No, tan. My wheelskins cover is getting a bit of wear too. I have a new leather from Land Cruiser Heaven, just haven't re covered it yet.
I don't have any good pics but we experimented with several Wood Lexus wheels on my son's LX. None of the US spec models matched up perfectly with single stage airbag options that we have on our rigs. They bolt up but the airbag gaps looked wonky. Finally researched it down to first Gen LS400s but none of the US versions were offered with wood wheels. We started searching in Japan and found one...called a Celsior over there). Paid $200 shipped for a brand new one and then purchased a 90-92 LS400 used airbag to match here on eBay for $25. Had to swap over the cruise control switch but that's it. Direct fit and looks like it came that way from the factory. I don't have a very good pic here at work but you can see it below.
If your building a show rig then go for it. My rig is a daily driver and it gets wheeled a lot too. I use the $11 wheel cover from Wally World. About every 3 years the velour cover gets pretty flattened out, and soiled, so I cut it off and buy a replacement at Wally World, again. This material is not very cold in the winter nor hot to the touch in the Arizona summers. I have yet to find a more financially/functionally Efficient method of caring for MY steering wheel. If YOUR steering wheel needs to be more creatively designed/ visually enhanced then more power to you. Some of the aforementioned techniques are certainly good for that.
Mine will be wheeled but it's also a daily driver. I don't like the open feel on my steering wheel. So if I can spend a couple hundred bucks and get one that feels good in my hands, that's inportant for us.
Could you give me info on where in Japan you got the wheel, I'm in desperate need of one.
I was wondering if the thickness was noticeable and you answered my question. Do you recall which color did you go with? I'm thinking Tan will match my interior but wasn't sure about the Oak color.
