Starter motor keeps cranking!!
Orlando, FL & Southampton, NY
Never had this happen to me, but I've read about it happening to folks here on numerous occasions, so I've always tried to prepare myself just in case it ever did happen :rolleyes:
Well, yesterday around 11AM, the family wanted to go grab some Dim Sum, so we all hopped in and when I started her up, the starter keep on spinning :oops:
Turned the key off, but she kept cranking :eek:
Tried to stay calm and turned the key back on so it doesn't load up the starter :meh:
Ran back into the house and grabbed a broom stick hoping I could beat it into submission, but she just wasn't having it :mad:
My wrench set was buried in the trunk, so I ran back in the house to grab another set, managed to disconnect the battery and she finally shut down :redface:
Tried connecting again, but she immediately wanted to crank over :confused:
Now, since I have a somewhat complex push button start, I figure I probably goofed somewhere and pulled all of the relays I have hidden in the fender out of their sockets, but she still wanted to crank over when I touched the battery terminal :bang:
I had wanted to pull the trigger wire on the solenoid, but couldn't reach it with the wheel in the way :doh:
Not wanting to miss out on Dim Sum and since I was sweating bullets from the heat wave we're having, we just hopped in another car and left her as is :(
Couldn't sleep all night cause I was dreading having to work in the heat, got up early this morning, pulled the wheel and was able to yank the remote plug, but she still wanted to crank :deadhorse:
Not a good sign, but at least I could rule out being a switch problem :popcorn:
Grabbed the lug wrench from out back, beat the living crap out of it and finally was able to reconnect without her cranking on her own :smokin:
Did a few test starts and all seems to be working well :clap:
I'm relieved cause this means I can get her to the shop and replace it on a lift instead of on my back :redface:
Now, I had replaced it with a reman from Toyota about 5 or 6 years ago, but put in an order for another yesterday just in case :hmm:
Not gunna waste time with the plunger and contacts this time around :meh:
What I DO want to look into is a main cutoff switch for the battery cause if this ever happens again, I want a fast and easy way to shut her down without having to search for tools :wrench:
this kinda junk that makes me want to get one of those battery disconnects.....
that and horror stories of stuck winch solenoids...
Yes, this seems to the theme lately. I had mine rebuilt by a local shop a few years back and wondered if it was really worth it as at the end of the day it was only $10 or $20 less than a reman from the dealer.
Be glad that nothing caught fire...
Starter causes fire
Are there any differences between the Toyota reman's and the Denso remans off the shelf?
Rock Auto has a Denso that's a little cheaper, but I'd have to wait a week, then send back the core and wait for a refund (local Toyota dropping off at my shop on Tuesday and doesn't charge for core)
Curious if the Toyo reman's are actually sent back to Denso to be reman'd or if Toyota does it in house somewhere :hmm:
According to Onur, Toyo remans are done at local shops in the US. The ones I have gotten were pretty pathetic when I opened them up to see why they didn't work. Both are now installed and working fine for the last year or so.
They didn't replace a worn plunger and both sets of contacts were in crooked. The internals were filthy with old grease.
It keeps on cranking because the solenoid is 'stuck' on (in) the contacts since the contacts have worn and formed a ridge. Just replace the solenoid/contacts and you should be good to go for a bunch more years...
This is a common starter 'failure' on our 80s.
cheers,
george.
It's sad to read that Toyota uses small shops in the US to rebuild starters?? I wonder if this is based off their model of parts production in Japan?
I replaced the plunger and contacts twice on the original starter years ago.
The second time around, I ended up snapping one of the cover bolts cause it was corroded :o
Worked for a while on the remaining bolts, but then I replaced it altogether with a Toyo reman as a PM.
Spent a lot of time on the beach the last few years including a few nasty saltwater crossings, so not sure what it's gonna look like when I crack this one open :eek:
I'd rather just replace it altogether than risk having it tie up one of my lifts if things don't go as planned trying to rebuild.
Same thing happened to me on my 40. Except the 40 has an extra "ballast resistor bypass" circuit that outputs voltage from the starter solenoid to the ignitor while cranking. So in addition to the starter not stopping, the engine wouldn't stop running. Finally got the power cut but then I proceeded to muck with it until I smoked the harness. Good times......
When I replaced the harness, I added this little gem:
37702-1AN0022 Cooper Bussmann | Waytek Wire
Nice little waterproof unit.
I have the ignition and accessory circuit on the "Fuse only" side and then the start circuit on the "fuse/relay" side. So far I have been very happy with it and plan to use it on other projects.
If I get a chance this evening, I'll post a pic.
A little update....
Thursday morning I took her into the shop, pulled out the old starter and compared it to the one the local dealer sent.....
Just my luck, they send the 1.4kw version instead of the 2kw :bang:
They said they had a 2kw in stock, but couldn't deliver it until that afternoon :rolleyes:
Asked if they had a new plunger and a set of contacts, but they had to be special ordered :mad:
Had to get to work in the Bronx, so I just pulled the plunger, cleaned it up a bit on the wire wheel, then threw it back in :wrench:
Started up just fine numerous times, so I headed off to work.
Went back to the shop early Friday morning and found the correct starter sitting on my workbench.
Threw it in and all is good :cool:
I have a 10mm wrench in the side pocket of my drivers door for just such emergencies (battery terminal disconnect). It happened to me and the gears got all chewed up. New starter from Beno and all has been well for a year.
