Stalling Diagnosis
San Francisco, CA
Alright so my dads 77 fj40 seems to be running great since we got the carburator tuned/jetted. the stock carb was a high altitude carb n we live in south florida. The only issue we face now is that upon a hot start the cruiser stalls out when making hard left turns, not formula 1 hard but unless you really crawl through a left turn it cuts out. I searched a bit and found some talk about a vapor lock, but it does not stall when stopping or sitting only while making left turns and there is no backfiring. What might attribute to this occurring? any help is greatly appreciated.
Jerome
maybe you need to adjust your float in the carb.
or just make 3 right turns haha
the float was all i could think of as well. but ill def consider the right turn idea:flipoff2:
thanks cam
yuor welcome, im fond of the 3 right turns as well,
its not vapor lock, sounds fishy to me.
I bet it has nothing to do with turning left. I could be wrong but I have never heard of such a thing. When it stalls, is there fuel in the carb? Check the site glass on the front of the carb. If there is no fuel then you have a fuel flow issue. If there is fuel, its probably some kind of spark issue.
In my experience, vapor lock is somewhat unpredictible but it can trick you into believing strange things like this. Poor some cold water on the fuel pump. If the problem goes away temporarily, then I would guess vapor lock.
When you restart it after it stalls on a left turn, will it stall again and again if you keep turning left? I bet it doesnt.
UUUHHH! This would be a good one for Car talk's brain teasers on NPR
When does it stall? What I mean is, do you go through the turn and it stalls while the clutch is in, or does it stall when you are accelerating out of the turn? Or are you gassing it the whole time?
Questions that come to mind:
Fuel starved or fuel rich causing the stall?
Any after-fire (at the tail pipe) or back fire (thru the carb)?
Did it back fire while you were tuning it after the rebuild? There is a valve in there that can be blown as a result of a back fire.
A missing injector or needle valve?
Check for loose electrical connections?
Sooo many questions...
I love these types of questions!
I had a similar problem with a 87 16v gti. if you stomped on the gas it would cut out, if you drove normally no problem...... it turned out that the accordion like air duct connecting air box and throttle body had a tear in it. the tear was on the bottom of the "v" so when the engine would flex under WOT it opened up and let too much air in, stalling it out momentarily. many :doh: :doh: before I figured that one out.
it stalls while pulling through the turn with your foot on the gas, full power then cuts out n zero power to the wheels. There was never any history of after or back firing with this vehicle ppre or post carb tuning. I will be heading home tommorow morning and will check all the needles, connections and the vapor lock possiblity by serving the cruiser up a nice glass of ice water. thanks for all the help.
Jerome
