square drive shaft
na
Ive heard of some running square shafts with out vibration for the rear, is this true? Im going to flip my rear springs to move my axle back some and was considering running this. the drive shaft place down here wants $350-400 and thats with me bringing him my shafts to use. any thoughts. i have a fj40 SB350/TH350/NP205
forget the square tubing, people run them up front often because its cheap and it works, but i would not consider the thought for the rear,
my suggestion is to call high angle drivelines he'll hook you up. 530-877-2875
http://www.highangledriveline.com/
I'm assuming that your rig is not a strict trail rig. So I would say stay away from a square tube shaft. Like camcruiser13 said call high angle.
If it was strictly a trail truck I say go for it. easy to replace and uber cheap. :D
That price for simply retubing a set of shafts is too high.
Square tube shafts are pretty much a hack that works for the trail but that's it.
Mark...
I run one in the front (seems to be a common mini truck mod). Would never run one in the back though... where i wheel the truck almost always see some road time.
just my $.02
My local guy retubed both my shafts for $35@. You should be able to find someone who can do you a little better than what you were quoted.
I'm in Kansas City, so if you are close by, bring them on down!:)
Ed
If your in WA, Aukeen driveline in Kent. Bill does nice work and it's not too expensive.
I live in homestead FL just south of miami, this place sucks for offroading and no shops
Shipt it to Degnol and have him get it done for you. Sounds like even with shipping it is cheaper for you.
