sleepycruiser
I will get by….I will survive
Here is my stupid question of the day. Will wheels from 2016+ fit on a 2011 with no spacers/modifications, etc?
Yes.Here is my stupid question of the day. Will wheels from 2016+ fit on a 2011 with no spacers/modifications, etc?
Thank you. Now just need to find some.Yes.
I just posted the entire hyperlink.I can't see your links, but this is what I use. It filters a ton better than the oem thin gauze ones.
EPAuto CP285 (CF10285) Premium... Amazon product ASIN B014TYRQUY
I go through more of these (and engine air filters) when offroading in dusty conditions and travel with spares.
And a 2011 RES remote!!
I see this one has the size listed at 7.5 by 8.5, the one installed in mine is larger than that when measuring the plastic that houses the actual filter. Do you remove the filter part from the plastic housing… is this the process to replace?I find I like this brand better for a little more. Side by side with the EPAutos, has about 30% more pleats.
https://www.amazon.com/dp/B01HAWMBH0/?tag=ihco-20
You just remove the filter element from the frame and replace it with the new one.I see this one has the size listed at 7.5 by 8.5, the one installed in mine is larger than that when measuring the plastic that houses the actual filter. Do you remove the filter part from the plastic housing… is this the process to replace?
I've been on that group and it is good. Even though it is horrible tech, Craigslist is another source. I've picked up new takeoffs for a fair price and sold rims/tires there as well.
Thanks. This is a lot lower price than oem charcoal.I find I like this brand better for a little more. Side by side with the EPAutos, has about 30% more pleats.
Not sure on the 11 but on the 13 LC you can run a generic remote.Thank you. Now just need to find some.
What are the negative effects of a tire rubbing the kdss bar at full right turn other then the obvious tire wear? For instance, does it damage the sway bar, etc.?
True with the constant wear. I had a 295 test fit and it only hits the KDSS bar a full lock turn as most people use the engine throttle speed…such as turning into a side load home garage to park. I’m more worried about hurting the KDSS bar.If you didn't notice it then it could lead to a blow out.
