Speedometer Cable - Grommet Question
Gardnerville, NV
Website
www.billetriflesystems.com
Oh wise mud... how does one put such a large item through such a small hole?
What's the trick here folks? I'm VERY doubtful that any amount or any type of lube will make this fit...
Cruiser Corps in Oklahoma City had them on sale. I ordered one and will post the number when it comes in or you can just call them.
Here’s what I did - these are blind grommets that I cut a slit and punched a hole in. They are more plastic than rubber. I should insert a rubber grommet around the plastic but probably overkill. I’ve thought of too to put some black gasket maker around it like caulk to seal it. Again probably not critical.
I ended up using the grommet that i slipped over the speedometer cable, then i used a spark plug wire boot to go inside the outer grommet. I had to cut the spark plug wire boot length wise to get it to go out but i think it will work just fine and doesn't look like a bag of dead cats. I wrapped the spark plug boot in cloth harness tape.
You could almost put that in the ‘best cheap mods’ thread.
Innovative solution Powerthief19.
Fuel line came to mind. If you need thicker wall.... a/c compressor or hydraulic line.
