Speedo cable length
Every time I want to pull my instrument panel out, I have to crawl under the FJ40 and disconnect the speedo cable from the running gear. It's too short to pull the instrument panel forward to disconnect it, and I can't get my hands in far enough to get any purchase on it. Pretty much I can touch it, but that's about all.
Is this normal?
My '77 is that way. I have never had to disconnect it at the bottom end but have never disconnected it without shedding blood. Replacement cable was the same way.
i can usually barely pull my cluster out and unthread the speedo there, but it is fricking tight.
Sometimes i just reach my hand up under the dash and loosen it before i pull the cluster, but it is pretty much a bitch that way too ;)
You can also track the speedo routing from from to rear and make sure it does not take any uneeded detours on the way up ( aside from the obvious detours away from the exhaust ).
yeah, it sucks to screw on behind the cluster, and I am sure I have smaller hands than most here
the last few times, I loosened it at the transmission, but to get that back with the O-rings intact is no small feat either :rolleyes:
I wish there was a longer speedo cable available - it's the #1 reason I avoid electrical work like the pest
Recently fitted Drew's EL wire to my cluster and had to remove it a few times. Everytime I had to crawl under and do the same, so if it is not "normal" then you are not alone, Brian :cheers:
And I just thought I didn't know what I was doing. I approach mine at the cluster since I don't think I'll be able to get it off and on at the bottom of my '72 FJ. My cluster has to be screwed tight in order to have a prayer at connecting the cable. Rerouting cable netted about 1/2" of additional slack and it doesn't screw on very well either.
Good thing I got a tetnus(?) shot last year because there's gonna be blood when that cable is put on or off. Cable sometimes comes disconnected by itself and the needle usually is in "bouncy" mode once the speed gets over 40mph. The Garmin GPS says that I'm running about 5mph over what the speedometer registers.
Is there a slightly longer speedometer cable that fits a '72 with original engine and transmission? Please sir, just 2 more inches?
screw-on type or clip-on type connector ?
link available ?
x2 on the longer speedo cables.
Also, trim off the small tabs on the bottom of the cluster. This will allow you to pull the cluster straight out and not have to bend it down to get back to unscrew (which can damage the cable too).
I have a long cable for my '71 that I bought because mine was too short. I used it for a few months before starting a frame up restore. Now I'm using an electronic speedo so the cable is stashed away in a box. Be happy to sell it if you want it.
link available ?
Mark A. sells the longer cable. Push type for sure...maybe the screw type also. Gives you plenty of room to get your hands in there.
John
A FJ25 speedo cable is longer. But probably too long. It runs across the firewall and down the passenger's. My 68 with a four speed added is pretty tricky since the four speed is 3 1/2" longer but needs the screw on type. For practice try removing the the upper door hinges on both sides. Speedo seems easy after that.
Now THAT'S funny John! Great perspective.
Add me to the list of peeps that grinds the tabs down on the cluster while it's out. Not off, just down.
And, while it's out, I've also gotten used to the idea of cutting 'open' the arch in the firewall brace behind the cluster so that you're not gouging the crap out of the cable when you tip the cluster forwards to get the tabs out.
And yes, longer cables are available. Call if you need one.
Best
Mark A.
resurrecting this thread... My '67 rig came with numerous spare parts, including two SOR aftermarket cables. The one marked "early FJ" was two feet longer than the original one, and the other one was 3 feet longer. I could see needing a few inches but not feet. Is this normal?
@bb67tlc - Good question. Since my '64 is missing its speedo cable entirely, I've found all sorts of conflicting info on how long it should be. Most places seem to indicate that early FJ40s through '70 or so should have a cable that is 91" long. I'd be interested in knowing how long your original is, as well as the 2 spares you have.
Hey Arne, looks like my PO/friend had bought the 91" replacements for some reason- perhaps he had trouble getting the instrument cluster out. The original one is around 68-69". Looks like Spector still has an aftermarket one for it- $22 doesn't seem too unreasonable to confirm that we're not going faster than 45 mph.
