- Thread starter
- #21
Great info in there, thank you for the thorough writeup! It sounds like B might be a bit much then for my setup, pretty much the same as yours, and based more on comments than number of votes Ia m currently trending toward setting up at C for my first try....As one of the "B" votes...
This is on my son's LC. We purchased his vehicle with a poorly thought out and installed OME lift and other frontend issues. One of the first things that we did to try and address the bad behavior (lack of caster, lack of droop, and excessive play in the steering) was the SPC UCAs. It was a night and day difference. Later in the process of exorcising the demons from the frontend, we also replaced the steering rack bushings, TRE, and rebuilt the steering rack and PS pump. It feels like a (very large and heavy) sports car now, compared to the nervous, wandering, disconnected from the road, pissed off beast with a punishing ride, that we purchased.
As a reference point, my son's LC is currently at ~21.5" (~+2") in the front, on 285/75R16 tires, OEM wheels, diff drop, no spacers, OME 860 springs/torsion bars/shocks, ARB front bumper w/ winch.
If I remember correctly from the last alignment, we're at ~1* over the factory recommended caster setting. It's probably a little overkill at this point, but his car feels and drives well, and about the only negative that I notice, compared to my LX, is a little "scrubbing" at "full lock". We could probably dial it back to "C" or maybe even "D" at this point, but we haven't been highly motivated to do so, because a little extra caster feels so much better than too little caster.
Similar previous threads:
any more votes out there, or even better, folks that have run C and D in a back-to-back comparison?
Between these, new lower ball joints (555's), tightening up the loose bearings (and reclamping a CV boot while I was there) it feels like a whole new truck! With the tire off, at full droop, with Iron Man Foam Cell Pro shocks, I measure just a shade under 24" hub center to fender lip.
