Recently, I purchased a 1973 Toyota FJ40 with the intent to rebuild it with my 14 old Son as a project car. We have a spark problem that has gotten both of us scratching our heads. I have replaced the starter solenoid, ballast resistor, rotor button, and rotor cap. Also, we replaced the coil, condenser, and threw a new set of points in it ("properly gapped"). I have checked all fuses, checked for voltage and continuity with a multimeter, reset the timing. The car runs, "sometimes" but seems to have a mind of its own. AT one time we had it running; rough I might add. We made adjustments to timing and carbourator and it seemed to get slightly better but nowhere near to perfect. At one point we found that #1, #3, and #6 were not firing; now nothing is firing. It's slightly frustrating. Also, I was thinking about worn lobes on the distributor, which would affect spark -right? I was wondering if you had any ideas that perhaps you think I ought to try?
