a tip on the "seam". I took some small diameter rubber vacuum line and cut it down the middle and used silicone and attached it to the seam to protect the sidewall. worked great. here's a pic.
NICE, that was quick... Glad I could lend some advice.
This old thread reminds me to let you guys know that I did a little damage to my sidewalls from the tire being extra high and rubbing on the 1" seam on the underside (See 1st pic top left corner). Maybe some black plastic to protect door edges from dings and chips would work here to protect your sidewalls? I now have a rear bumper carrier but just thought I would let you guys know what I noticed on my Coopers.
I started to do the this mod then noticed the tire was hitting that seam. I didn't think about hurting the tire, but I was worried about rubbing that seam down to the bare metal and causing rust. Might be something to keep an eye on.
aaron
Cross member bolts were ... 8x1.25mm and 70mm long
Hand Crank bolts were ... 8x1.25mm and 30mm long
Heads on the bolts I used were 13mm instead of 12mm
I would use 40mm next time on the hand crank bolts ... I had to shave off a little of the spacers to get the 30mm to work.
Was looking at these bolts in 70mm length are these what I should be getting for correct size? How many do I need? Have no idea the difference between a 13mm head and a 12mm head. Assume it is the size of wrench I need to work with. Guess these are 10.9 which is weird sizing, as does that make them 11mm wrench? Any help understanding bolt sizes is appreciated.
Chrome Bolts, Stainless Steel Bolts, Metric Bolts, Socket Head Cap Screws, Grade 8 Bolts, F911 Bolts
spartan said:And you get this - 33" is max tire though.
I read an earlier thread also raising up 2", so I did that, and that was cool, but I just came across this video http://www.4x4tv.tv/Project-80-4.html which shows how to get 5" of lift, so, I'm picking up (10) 8 x 1.25 x 150mm bolts tomorrow, to re-do the mod, and stuff that puppy waaaay up in there.My guess is 2", he used 2" long nipples.
Not true, I fit my 315/75/16 BFG KM2 (34.4") tire under there with the spare tire lift kit. No trailer hitch though. And about 1/4" clearance to the panhard bar
