This is very interesting. If they are modifying the globes to suit the 100, could they further modify them to suit heavier loads?Pleiades sell replacement globes. They are not genuine Toyota, they are Citroen with the pressure modified to suit the 100. They come with a thread adapter fitted. They are a direct screw in replacement.
What are your pressures?I bought two rear Pleiades globes that were shipped last Thursday from the UK. They arrived on my porch in South Alabama today. Two globes including four day shipping was $352.52. I bled AHC fluid, used hammer and chisel, easily got old globes off and installed new globes by hand tightening. The LX was very bouncy in the rear. Now it is buttery. I am losing fluid from the DS front shock area but not sure why. Im hoping all the pressures will settle and leak will stop.
Techstream, if you're ever traveling through Atlanta hit me up.Have not idea about the pressures. How is that done?
For those that aren’t interested in dealing with the vagaries of getting pirated Techstream up and running or aren’t willing to purchase an iCarsoft TYT 11 then go old school with a pressure gauge. It eliminates any potential spurious ECU processed pressure readings and you get accurate readings where they matter.Techstream, if you're ever traveling through Atlanta hit me up.
Put it together from an SSBC brake kit (just for the M7x1 adapter to replace the bleeders) a couple of aeroquip -3 AN to NPT fittings and a length of -3 braided brake line. On the vehicle’s I’ve compared Techstream to gauge readings I’ve found unanticipated disparity. The FSM states that you’ll see an approximate difference of 1.2MPa between Techstreams value and actual. I’ve found the spread slightly less, on my own vehicle for instances to get the desired 5.7MPa (825 psi) at the front damper I’m reading 6.7 on Techstream. Other vehicles have yielded similar results. A gauge is useful after you’ve done something like fit new coils, spacers, sensor lift etc where you may get initial spurious Techstream readings, numbers that are in the 2s and 3MPa range that clearly can’t be correct based on the work you’ve done. It’s also handy to overcome Techstream interface/hook up issues on ROW vehicles.Where does one purchase such an item? Or is this a build it yourself kind of thing?
It would be interesting to compare a mechanical gauge reading to that of Techstream simultaneously.
I have found new Toyota globes in the US for $285 each shipped. Is there a deal better than that?
Well I just pulled the plug on two rear globes for $570.
I paid for two globes on eBay for $570 then cancelled, got a refund and bought globes from Pleiades in the UK for $352 shipped in four days. And the seem to work real nice
