I have turned T bars several turns ever so often to help keep pressures correct. I just turned them again several times with about 3-4 threads left on each side. Both sensors are the same in low on the sliding bracket. The pressures were 6.7 front, 6.9 rear and accumlator always at 10.6. The DS stays about .5-.75" lower in front and rear.Sensor adjustment can't do anything for leveleing L/R. As said, there is free flow of AHC liquid between left and right as long as you're going slow or straight. The only way for you is to tighten the DS torsion bar (re-indexing if you're out of threads on the adjuster bolt)
Steering angle you read in TechStream.
Bonjour,
Certains ont-ils commandé des globes chez Jpanime sur Ebay ? Selon vous OME ?
Merci à uHu pour tous les conseils.
Then you just have to continue turning the DS until you have the same physical height on both sides. The AHC will not do anything for a L/R lean.I have turned T bars several turns ever so often to help keep pressures correct. I just turned them again several times with about 3-4 threads left on each side. Both sensors are the same in low on the sliding bracket. The pressures were 6.7 front, 6.9 rear and accumlator always at 10.6. The DS stays about .5-.75" lower in front and rear.
Ahhh. Now that makes sense.The AHC will adjust the front height until the average between the 2 sensors are zero.
I have not heard anyone complain about their impex globes with failure unless they had not properly managed their pressures in tech stream and height of car in front and back was off. That will wear out even new globes and battering rams/ struts faster because pressures need to be in line. I assume yours are? If haven’t checked check them. Your issue could have been that all along and not the globes from impex. I’ve ordered brand new original control arms to hub assemblies to bearings to many other parts like brake lines etc from impex, no way those are fake.Bumping this for 2025
Right now a set of four globes is US$442.34 (49141-60010 TOYOTA ACCUMULATOR, FR and 49151-60010 TOYOTA ACCUMULATOR, RR) sourced from Impex before shipping.
Any comments on the three questions above in terms of counterfeits being sold?
- Has anyone received Impex globes with OEM style date stickers?
- Does anyone have any concerns that these might be high-quality counterfeits?
- Has anyone received globes from seller "jpanime" or "seagulls_japan" or "ASRparts" on eBay?
Bottom picture looks like the ones I recently received from Impex Japan.I bought some impex globes a long time ago, but never opened the boxes to install them. Doh! It looks like I got the wrong ones. Has anyone seen globes like these (bottom one with long male thread)?
View attachment 3880947View attachment 3880957
The procedure is, as always, first get the heights and pressures in spec, then do the globe test with counting gradations on the reservoir.My New to me 2003 lx470 has close to 200K miles, but all the globes have 2003 dates, She still raises and lowers. But she does seem to ride a little rough.
Think it's time? OE, Impex, or Other?
UPDATE....on my 2001 LX, I continued having the NW corner globe not holding pressure as it should creating harsh bump recovery. I replaced that one cheap Amazonian globe, that didn't last long at all, with another cheap globe I had on hand.Mud update, as promised.....it appears the front DS Amazonian globe is not retaining pressure as it should. I can tell the NW corner of LX is lacking a bit in suspension damping. I will continue on until.....
