Solid panhard rods 411
The Old Pueblo
For those with solid panhards, like the ones MAF and Slee sell, just a little warning to check the front one constantly for stress. Solid is weaker than tube and the bend over the control arm makes it even weaker and vulnerable. CHECK yours for stress cracks!!! It seems mine had a crack in it for some time, as we found some rust where it broke. I never noticed the damage.
I've had one in my rig for less than 3 years and over the weekend it snapped on the trail. See the story and some pics here https://forum.ih8mud.com/az-copper-state-cruisers/365421-axle-deep-quick-sand-broken-panhards.html
I'll be making a new one out of 1-1/4 .250 tube. I'll never do solid stock again.
WOW! You are the first to bust that! Congrats! Will check mine for sure.
attachment.php
The oem is also solid.
Ya but the rear is hollow. Don't know what Toyota was thinking. Both should be hollow. And that bend???
Hollow schmollow.
:lol:
IIRC, the front panhard is not solid. It is tube as well. At least, that is what I recall when I welded in the adjusters, but that was 6 years ago now.
EDIT: I'm going out to the shop to check. I have a spare front and rear just for this type of situation. :)
EDIT 2: Solid. How the heck did I put the adjuster in back in the day. My memory is failing me miserably.
Hollow is stronger than solid rod.
It is more complicated than that. For a given diameter, solid is stronger. For a given weight, tubes are more rigid. For tensile strength, the cross sectional area of the steel is the important factor.
The front panhard rods I have seen are solid, but I haven't seen that many to tell whether they were different in other years.
The front rod is solid and I can't imagine using a hollow tube with a bend for this application. However, I'd like to see what Alvin comes up with that is as durable.
Glad to see that your family was ok.
Notice the poly bushings - these add a lot of stress to any link system. Stick to factory rubber.
I doubt the poly bushing had anything to do with it. It's been used in link systems for years and is preferred. Race teams use them.
Race teams don't twist like wheelers do. I have blown up tons of poly bushings in the past, they are horrible for crawling use, poly is definitely not preferred unless it is surrounded by a nice spherical joint.
Having said that, I doubt they caused the failure, either, but it wouldn't have helped if that panhard had a weak spot.
Race teams also replace half the truck (if not the whole thing) every race.
Poly is much stiffer than rubber, hence the extra stress. The factory rubber will flex and absorb more force while the poly will transfer that force to the mounts and/or the bar. Hence why race teams use it, they want everything stiff.
Not saying that you can't use poly, just that it IS harder on everything around it. I think for 99% of applications it's fine.
I don't think it will have the exact bends of the OEM by the time it's all said and done. Should have something in a week or 2.
Tube is not stronger than solid in the same outer diameter. Pound for pound, tube is stronger- people hear this and don't look any further into the story. If you're using the same weight for length, the solid rod is smaller in diameter, the tube is stronger due to mechanical advantage.
Toyota uses solid on the front panhard so they can bend it the way it needs to be bent. The rear is straight, so they use tube. You're not doing yourself a favor by making a front panhard from tube.
I'd bet good money your failed panhard was OEM. You're the only person who's ever broken one as far as I can tell. Don't re-invent the bar, get yourself another one. You probably had some kind of fault in it, or it was the bushings that over stressed it.
