Solid panhard rods 411
Tube is not stronger than solid in the same outer diameter. Pound for pound, tube is stronger- people hear this and don't look any further into the story. If you're using the same weight for length, the solid rod is smaller in diameter, the tube is stronger due to mechanical advantage.
Toyota uses solid on the front panhard so they can bend it the way it needs to be bent. The rear is straight, so they use tube. You're not doing yourself a favor by making a front panhard from tube.
This Mechanical Engineer agrees 100%.
Tube is only good when: 1) straight 2) loaded axially or with torsion 3) has no dents
OEM has a double bend to it while the aftermarkets have a single one.
Actually RHD fronts has a single bend, but LHD has a double. All front OE ones are solid.
Alvin, does that bar have a single or double bend? Can't see from the picture. If single it will hit the front diff on compression and that might be what caused this, if it repeatedly did that.
It is possible you got a RHD panhard. I saw in the other thread that it was a MAF unit. Did you check with them?
Also, are you sure it cleared the diff protector that you have on the diff?
attachment.php
Checking in from work real quick.
Yes it has a double bend. 1 bend over the control arm and another slightly outward in front of the diff and it does not touch the diff guard even when the axle is fully compressed.
I'm holding off on buying the tube for another day or 2. I'm glad to see a mechanical engineer chime in. I consulted ours here at work and he thinks there are many factors, but not being familiar with the application, can't make a sound judgment either way.
Can you post up a better picture of the actual break/fracture? The surface would be best (looking down the rod).
From the looks of the picture you posted, it looks most like a compression failure. I'd bet due to a material flaw.
Other failure modes:
The rod has been welded back together and gusseted so I could drive home. That's the only pic I have. It had been previously cracked in the under part of the bend. When we took it out it had some rust there. It was not a noticeable crack, meaning I never spotted it despite being all over the front axle 2 weeks ago.
Not sure what MAF sells, but we have both. LHD and RHD versions.
My mistake, from the looks of things I thought you were sourcing them from the same vendor.
I personally prefer the DIY joints and have posted that many times. I saw the missing bend before and just assumed it was a not needed detail and never gave it any thought that it might be something for a RHD vehicle.
So the consensus on the board seems to be that I should stick with 1" solid stock.
I was planning on using 1-1/4 .250 DOM tube for the new rod. I can't imagine 1" solid is stronger than that. Maybe no one noticed I said I was planning on using 1-1/4 .250 DOM.
Does that change any opinions.Thoughts?
Thanks to all for the well wishes. It was a scary thought, what could have happened if I was hauling ass when it broke.
You're right, I missed that. It's very possible that the 1 1/4" might be stronger, you'd have to talk to a mechanical engineer. However, you're still the only guy known to have broken a solid bar, and apparently an aftermarket one at that. (Just what was the advantage to aftermarket, anyway?)
I think consensus is that is was a freak incident and you should just get another one. This is simply not a failure component and is if anything overbuilt. The lesson here is that we should all inspect our rigs and links on a regular basis. It seems that there was stress evident before the failure and yet it was still strong enough to hold together and start rusting.
I like the MAF 4+ bar, because of how the spherical end assembly is added to a stock bar and the fact that what little rotation is required with that bar is completely unrestricted. You get factory rubber on the axle end and the spherical joint on the frame end. Perfect panhard application, IMO.
I run them front and rear.
The solid 1 inch rod would have about 33% more steel than a 1.25 inch .25 wall tube, so it would be 33% stronger in tensile strenght.
That suggests that equal weight is equal strength, which is not true in this application. I don't know if tensile strength is the proper specification here, breaking strength and/or plastic vs. elastic deformation specs would probably be better. I'm way out of my league now in this discussion though, so carry on. :D
pardon my ignorance here and sorry for the slight hijack: considering that the panhard bars only move in the Y axis (a whopping 5 deg at max?), what is the benefit with going anything other than rubber or poly bushings at both ends? What advantage is served by a spherical joint, which I presume allows travel in the X & Y direction? I can see the benefits in the control arm situation but not seeing it in the panhard rod situation.
thanks.
The panhard does see some twisting force as the axle moves through the arc dictated by the control arms. Personally, I think the OEM rubber bushings should be sufficient for this, but the extra range of motion that a lifted and often wheeled vehicle sees was not forseen by the Toyota engineers and it's possible the rubber bushings are not sufficient, or that less binding might improve performance. I definitely wouldn't use poly myself, but that's just my opinion with no facts to back it up.
I'd double check you math on that one. I was doing some stress calcs on both of the shapes and the tube was equal or better in every case.
Then I looked at something very simple.
Cross section area of bar = pi*R^2
3.14 * .5^2 = 0.785 inch^2
Cross section area of tube = pi*R^2-pi*r^2
3.14*.625^2 - 3.14*.375^2 = 0.785 inch^2
So by a major coincidence, the bar and rod in question have identical cross sectional areas and therefore will weigh the exact same.
So for the 2 items in question the statement above about "pound for pound tube being stronger than bar" holds true in this case.
tension/compression - tie
bending - tube
buckling - tube
torsion - tube
And seeing as how you would need a jackhammer to "dent" this particular tube, I don't see a concern about tube denting being valid in this case.
bending - tube
buckling - tube
torsion - tube
Werd! I always appreciate the mechanical engineers. I work with one and it's great to ask him questions and see him get all into it. Thanks Dave.
Now, the big question is- if you bend that 1.25" tube into the required shape, does that compromise the strength more than bending solid 1" rod? The factory sway bar has some pretty serious curves in it, but I don't know if they're required on a lifted truck. I would assume so, as the suspension can still collapse to nearly the same position.
