Hey John I've had a v8 conversion done (not by me)but yet to do a build thread yet. My front drive shaft was redone and down sized near pan to t case.hth
It's totally not the proper method, but I massaged the pan while it was in place, no heat, and still full of fluid. I just went slow and dented it a little at a time.
Hey John I've had a v8 conversion done (not by me)but yet to do a build thread yet. My front drive shaft was redone and down sized near pan to t case.hthView attachment 1220563 View attachment 1220562
I agree with this. You're going to have to resize your front driveshaft anyway so have the shop narrow the shaft to buy you some clearance. I think I spent around 275 to have this done and the front and rear driveshaft lengths altered.
For what it's worth, I've run my truck a bunch in 4wd high at 25-30 mph (lots of snow driving) and had some minor rubbing but no issues with drive shaft clearance to the trans pan. I have roughly 1/8" clearance and all is well. This seems typical of vortec/4l60e conversions.
Looking good, Man! Keep it coming!
-Ed
I used no heat.. just tapped on the pan to get a little clearance. The metal on the pan is really soft. There were 2 plans for the 4l60. Cars use a short pan.. I have thought about install a short pan on my lx450 swap, but haven't yet.
Hey John...if you need any dimensions let me know. I'm probably 20 minutes away if you'd like to check my conversion out, I'm home all day today.
The fuel tank connection, if it has three prongs, then it is to be connected to a Delphi fuel pump, which I don't think you are running.. The evap vent connector goes to the evap canister vent solenoid.
Don't think your engine came with one, as it usually is found near the fuel tank...
This where I put mine.
