No hacking... you are taking the time to pull it all apart properly so soak those bastards and pull it off properly and put it on the classifieds.
As for the hood, that can be done all by yourself. Keep the prop up like you have it then go through and start loosening everything evenly. Then take the rear most off first then the front. If you stand in front of the truck and let the hood come down slowly and then pull it up and away you can basically pull it straight off like a large piece of plywood. I was able to do it on my own with no issues.
Word to the wise though, mark the mounting points and trace the brackets on the hood so that when you put it all back together you dont really have to worry about aligning it.
