I see a few threads that list the needed bearings, is there a source for the vanes or a complete rebuild kit available?
Rather than ruining a valuable piece of unobtainium smog equipment that someone might need, why not just get a pump replacement pulley? FJ40jim sells one.
www.tlcperformance.com
You can leave everything else intact. Air Injection sys will just not function. You can disable the other systems with BBs in the various vacuum lines.
If you want a nice, clean OEM solution to plug the air injection ports in the cylinder head fork over some big bucks and buy six of these:I disagree with this statement Alf. I would remove and cap the air injection system at the very least.
The tubing on the air rail is comparatively thin. It relies on having the relatively cool air from the pump going through it to help keep its integrity. Without the pump, it is subjected to pure exhaust heat, which will hasten its demise.
