Skinning the inside of a pickup tailgate
Scottsdale
Ok, I have spent an hour plus searching thru old threads looking for the post someone made of their tailgate interior skin. I’m curious what thickness of aluminum they used. Anybody care to help a brother out?
Thanks!
Dave
Hey Dave, I made mine from 16 ga ( .0598", 1.518mm) 304 Stainless steel. If you go with Aluminum, I would go with 8ga Al .1285". Bear in mind you might get some interference in the bottom corners with a thicker material near the hinge as there is a sheet metal feature on the bed that is present. I've attached my 2D drawing for reference, drawing is not complete as I pull data for mfg from the 3D model. If you are interested in a stainless one, I can have my shop make one and drop ship it to you. You would just need M6 screws and 30 rivnuts to complete the install. Price is $160 plus shipping.
Cheers, James
Thanks!
Dave
Hey Dave, I made mine from 16 ga ( .0598", 1.518mm) 304 Stainless steel. If you go with Aluminum, I would go with 8ga Al .1285". Bear in mind you might get some interference in the bottom corners near the hinge as there is a sheet metal feature on the bed that is present. I've attached my 2D drawing for reference, drawing is not complete as I pull data for mfg from the 3D model. If you are interested in a stainless one, I can have my shop make one and drop ship it to you. You would just need M6 screws and 30 rivnuts to complete the install. Price is $160 plus shipping.
Cheers, James
You probably have a great Cruiser and want to keep it in this condition.
Since it is an exterior use ( and getting wet even in the desert), an additional consideration for your review.
Keep in mind that use of aluminum could result in dissimilar metal corrosion (i.e., galvanic corrosion). If aluminum is used, it should be passivated and separated from contact with the steel (even the fasteners).
Agreed. Stainless is the new plan.
Words I had to Google ….. 😊
1) Galvanic Corrosion
2) Passivated
I would love to get a “bridge” like this for the gap between trunk and tailgate. Does anyone know where to get these??
I am a bit confused. We are talking about a pickup, correct?
Why not just buy a complete replacment tailgate (which is what I did on Speedy)? It was not expensive.
HZJ79L-TJMRSVJTFLB71J518001372
CategoryPart NameOEM Part NumberQtyNOTESDescription
Main Sheet Metal & FittingsGate Assy, Rear Body Tail65700-90K031The bare metal tailgate panel (arrives in black e-coat/primer).
Main Sheet Metal & FittingsHook, Rope66311-90K003From what I can see the tailgate comes with these already attached, but perhaps check?The external metal tie-down hooks bolted directly to the outside of the tailgate.
Main Sheet Metal & FittingsMark, Tailgate (Decal)75459-60031-A11"TOYOTA" lettering decal (A1 = Light Grey/Silver, A2 = Dark Grey).
Latches & StrikersLatch Assy, Tail Gate66170-954022Same comment as for the Hook, Rope aboveThe locking mechanism bolted to the left and right upper sides of the tailgate.
Latches & StrikersBolt, Tail Gate Male66121-950122This is the pin that serves as the hinge
Latches & StrikersScrew, Pan Head (For Latch)90150-500054Same comment as for the Hook, Rope aboveHeavy-duty screws used to mount the latch assemblies to the tailgate shell.
Hinges & Mounting HardwareBolt, Flange (For Hinges)91551-805164Standard M8 flange bolts to secure the hinges to the bed frame and the gate.
Support Chains & BuffersChain Assy, Tail Gate66280-954032Toyota occasionally supersedes with 66280-37010; but I think I already bought a setThe complete metal stay chain assembly with protective sheathing.
Support Chains & BuffersCushion, Tail Gate Side66324-600102The rubber bump-stops/buffers that mount between the tailgate and the bedside.
Screw90150-500052Screw to hold the cushions on
Support Chains & BuffersBolt, w/ Washer (For Chains)90119-08A782The specific bolts used to anchor the base of the chain assemblies.
The factory tailgate has no cover on the inside allowing any load in the bed to bang into the gate under acceleration. Skinning it also provides a nice place to sit and a nice flat surface to prep food etc
You can also sit on the factory (unmodified) tailgate and after your legs go numb, it’s quite comfortable. 😊
That is very, very fancy!
But how do you stop water from ingressing in the various fancy boxes that you access from above?
The top access boxes in the drawer system are not weathertight by design to store things that can take a little moisture. The two main pullout drawers are weathertight. They are also synthetic carpet lined to stop things from moving around so much. We keep the tents, camp gear, food etc in there. This really helps with the storage topic on these trucks, plus the top is rated for 2000lbs load. They are lockable too.
My 75 came with a bed liner which has a plastic skin over the tailgate, FWIW. It's made in New Zealand but obviously for the Middle East market. It does a pretty good job protecting the bed but boy is it slick. Any cargo left untied will quickly slide in any and all directions. The truck came from Riyadh so I assume it's something that can be had. I never saw another one while living there but it also wasn't something I was actively looking for.
