side window protection
I was leaning towards only two or three 1"D tubes as anything more becomes asthectically unappealing and will reduce the available light in the cargo area. I have more issues with trees than rocks in the area of the rear windows so the tubing would a better option for my application.
Without adequate support the mesh will likely deform easily but the gap 7schulz mentioned might be just the ticket.
It seems to me that doing just the tubes will likely cause more problems than prevent it, especially when tree branches are the concern. The branch could get lodged in between the bar and the window and cause breakage rather than deflecting off of the glass. The best bet would be a combination of mesh and the bars but it would look ugly as sin! I'll build whatever if people want to buy it but I don;t think this is ever anything that I would consider making as a production item. It would give you the cool Mad Max look
The problem I see is anchoring them on the inside.
I think your best bet would be to fab up a bracket that fits on the inside that wraps around the window on 3 sides (a U shape). Would be easy to slide up and then you could run bolts from the outside to captive nuts in the bracket.
If strength is a concern you could bring a leg/support off the inside bracket to the wheel well and anchor it there. Would give some triangulation and a ton of support, so would be a lot harder to dent the body panel.
Just thinking out loud.... :hhmm:
A few other Ideas.
https://forum.ih8mud.com/40-55-series-tech/385953-fj45-troopy-owners-i-need-picture.html
This isn't the exact picture I was thinking of but it works.
here is the oem side 1/4 window protection bar...and part #rs
one bar like this would be enough to make it too small to clime in thru.
It comes down to purpose. This is great for security, but it sounds like some posters are interested in protecting the windows from breaking at all.
I agree that this is doable, but it would be hard to make it look good.
:steer:
I thought the OEM bar was mounted on the inside?
It is. Great for security, not so great for keeping branches/rocks/etc out.
And Zombies. Don't forget about Zombies...
National awareness month after all ;p
An issue I see with the outside protection like the pic above and comments on tight trails; I can see just about any branch getting caught in the amour and then using it as lever to really break out your window.... and whatever else to body its mounted on.
Mot makes screens for the 1/4 windows correct?
have him use a wire mesh instead of cloth mesh...then your all set....to keep stuff out of the truck when window is open.
a smaller wire mesh...but...you get the idea
Only if you internet shop.....Then everything is pricey. 4x8 sheet of expanded metal I bought yesterday was $46
That's not too bad - guess the last time I looked was a while ago, and was probably a small sheet at Atwoods or something.... I bet I'm thinking of the diamond plate I looked at! Guess the mind is weaker than I thought.
Was thinking about this today..... And if going this route would make the window guards removable and do double duty as sand ladders.
Take the Sand ladders off of the troopy in the attached pic and mount them higher over the windows
