Degnol said:
Their shop rate manual should have what amount of time they would charge you to R&R the stock engine. You've removed the old one, so they will have to fab brackets and do some engineering, but maybe they would give you a range?
I'm guessing, but if they charged you the total time for R&R, you might be close.
I hate to have to pay people to learn on my junk, at my expense.
Good luck....tough one.
Ed
I highly doubt it...
What engine is the 2UZ-FE? Is it from the Tundra?
This would be nowhere near a R&R... If this is the kind of shop you want doing your work, pay the hourly rate. This not a simple "cut and paste" operation. I lot of shops would tell you straigh up - "F Off".
Integrating an OBDII engine, tranny and t-case into a vehicle with no computer and wiring at all is going to be a cork soaker. It is all the little details that will kill you. You want PS? Auto? Linkages to work? Cruise? AC? Each one is a challenge to integrate to your Pig.
The shops that say "no problem, here is your price" are the ones that worry me. I had a engine from and Integra swapped into my Civic. I did it remotely, from 400 miles away. This is a simpler swap, and they quoted me a price. What I got was unsat. Throttle cable fell off (in the middle of nowhere), radiator was mismatched to hose size - their solution? Double clamp it!!! AC compressor was using 2 of the exisitng 4 bolts to mount up!!! Shifter linkage FELL OFF the tranny at 3 in the morning in a place where it is not good to be white and out alone. They ran the wrong crank pulley so I had a v-belt riding on a ribbed pulley.
All I had to do were grab diff parts from a couple other cars to get the correct rad, AC compressor and throttle cable. I bore you with this story, because I had to un-**** my car from 400 miles away. My buddy's shop did it all, and he said, "Boy, I wish I had done this the first time!" He liked the project, but he couldn't have done it as quickly, but I feel a heck of a lot safer driving that car anytime, anywhere after his shop went over everything.
So if you want it done well, let someone take the time to do it right. If you don't have time to do it right the first time, you sure will find the time to do it right the second time (or third, or fourth)
Do it right, that way you won't get frustrated, give up, and sell the project as unfinished for pennies on the dollar!
