tiorio said:Shoot, I'll need someone to have a couple![]()
with while they install my junk. Living the life of the garage-less is kinda annoying!
kemasa said:What do you need to have installed? I installed the springs in my driveway. I am not sure that the garage would have worked due to how high it is when on the jack stands, not to mention a lack of room.
kemasa said:I got the caster correction done by MAF. My Cruiser is back to how it used to drive, the wandering is gone now. Well, wandering is not quite accurate, it just was not as stable as before. Quite nice and I am glad that I got it done.
I got to MAF around 8:30am, they open at 8am. They were just getting the vehicles out of the shop (slow start on Monday?). While I was told that it would take 2 hours, it actually took around 3, in part because they did not get started right away. The actual time to do it would be more like 1.5 hours or less. This is one issue which they should learn about which is setting false expectations, which was more of an issue since I was waiting (I did learn a few things about large trucks which I did not know, watching them work).
It seems like there is really only one mechanic, although perhap normally Robert also does work, but it seems he had to go somewhere. Clearly MAF is not a high volume place.
I did talk to Al for a bit and he seems like a nice guy and he seems to be trying to make improvements.
Overall, it worked out well, but I think that if I were to have to do it again I would just leave the vehicle and come back later. The price was the best that I could find and I have no issues with the work performed. They do have a "lunch room" that you can wait in, but that is best to avoid (dark and not much air flow and the seats are horrible, the seats in the parts area is MUCH nicer), a chair is a better option to sit under a nearby tree. I would recommend them, with the warning about the timeframe not being accurate. The best thing to do is to find something else to do (there is a bus line nearby, which is free to the Metrolink Station, in case you want to go away).
T Y L E R said:Dude .. it's a shop. What did you expect ..![]()
TY
tiorio said:But schedules are schedules and time is money!
kemasa said:I ended up going outside and sitting under a tree.
HIPPIE!!!
kemasa said:Personally, if I owned the place I would trash all the chairs in the room, perhaps either burning them or running them over. I don't expect a day spa either, but I would also be concerned about lawsuits. One set of lights did not work and so it was a bit dark, there was a broken chair on the far side. I did not try one of the chairs, but the one that I did was not great. I ended up going outside and sitting under a tree. The reason for my mentioning it is so that others don't consider that as an option, It is nice that it is there and they will let you use it, I just wouldn't.
kemasa said:What part of that don't you get????
kemasa said:Well, I don't drink beer
