This problem is starting to irk me, everytime I think I've figured it out, turns out I'm wrong. I start driving down the road and at slower speeds (driving straight) the whole rig starts shaking. First I thought it was my tires (33's), I bought some 35's, newly balanced, still shakes (maybe more so). I check my steering arms, driver's side loose, torque em' down, 49 ft/lbs - still shakes. So I start grabbing my wheels and shaking them to see if I can feel sloppiness in hub bearings, knuckle bearings - nothing, except...
I notice that my TRE's are twisting and lots of movement in my tie rod and relay rod. Now, I have a Scout power steering setup, so I only have the Tie and relay rods, the TRE's are most likely OE, and I remember the very first instance of this was the day after I finished my PS conversion. So is it likely that totally wore out TRE's could cause massive vehicle shaking, even if you're going in a straight line? I've also inspected my springs, u-bolts, shackles and shakle hangers, and frame and can't find any cracks or looseness. Any opinions???
