Shimmy/Shake Prob
When I did have the caster shims in, I had the thick end towards the front. It worked great before the s/r, when I did the s/r it tended to wander all over the road. Pulled em out, and everything was O.K.
But, let's just say for continued problem solving sake, I go ahead and chek out caster (which I might as well, just so I know it's right), is there a do-at-home method for finding your castor angle without taking stuff apart?
Have you replaced the bad steering box yet? I do not see how if you have a bad spot in your steering gear, and the thing is leaking, how any real diagnosis could be accomplished with a junk component in the system.
Who’s shackle reversal kit did you use, if you used a kit? There are systems out there that require the use of a caster correction shim in order to get things back in line.
Could you post up any pictures of your set up?
It could be that your caster was off all along. According to your previous posts, this issue did not develop until you installed the power steering. If the drag link end that attaches to the pitman arm is marginal, this problem will continue, even after the box is replaced.
Steering stabilizers were designed to limit bump-steer, not death-wobble.
I bought an inexpensive angle finder (from the welder's supply house) with a magnetic base. It's only accurate to maybe +- 1 degree. Not great but it moves me from the bleachers to the ballpark. ;)
Measure the angle of the front pinion with respect to the frame. The difference is caster.
Actually, you want to measure the angle on the machined top surface of the knuckle that the steering arm bolts to with respect to the pavement. You need to put a straight edge on the flat to get the angle finder on in. Then measure the angle of the pavement. The top of the knuckle should be angled rearward at least 1 degree. 3-4 would be better. It is probably only accurate to +/- 1 degree, but it is better than guessing.
No Steve, haven't replaced the box yet, no cash. But it will be done within the next week or so.
The shackle reversal kit I used is MAF. But now, I can't seem to remember at what point I had the shims, and then at what point I removed them. I seem to be under the impression that the MAF shackle reversal is designed to retain proper caster. Looking at the add in the catalog, shims don't seem to be included in the kit, and I can't find them in any of my receipts. The shims may have been sent in acompaniement with the 2" over stock shackles that I bought for the rear, or the MAF s/r. I think now, that I put them on when I did the s/r, it made it wander, removed them, and everything was fine. If that's the case, the shims were only in a few days; but, I still can't remember exactly.
-If the drag link end that attaches to the pitman arm is marginal, this problem will continue, even after the box is replaced.-
Explain this one more time;^)
Pin_Head, this probably can't be done with the tire off, can it?
Yes, it can, but it is probably more accurate to measure it with it on. To do it with the tire off, you would have to first measure the angle of the axle houseing (or some other reference point) with the tire on and after you take it off to see if this angle changes.
The pinion flange angle is supposed to be 90 degrees (vertical) when the caster is +1 degree, but I don't know how accurately Toyota set this or whether someone has fooled with the axle housing by turning the knuckles, which is why I recommend measuring it directly at the knuckle with the wheel straight ahead.
Thanks. My bad. I think I'll go home and remeasure mine. :o
Tie rod ends attach the tie rod to the steering arm at the knuckle.
Drag link ends attach to the pitman arm on the steering gear on one end, and the other end can either attach to the tie rod, as it does with the Land Cruiser, or to the steering arm, as it does with many other set ups out there...
You stated that you replaced ' all the tie rod ends, except the one at the steering gear ' in a previous post... IF the end that attaches to the gear has slop in it, and not replaced when you change out the steering gear, you will continue to have slop in your steering system.
You may want to spend the $40 to have an alignment done on a lazer alighnment rack. for the money it may be teh best way to figure out what is wrong with you allignment/steering setup.the hunter systems have a very detailed accurate measure that could give you some insight into your pproblem. they are also a good way of finding minor slop the mechanic will be able to help locate problems.
I don't think that the box should be the problem. I do believe that it may be a safety issue that you should fix, but a properly set up steering system should drive without wobble in a straight line on a straight, flat road with no box or pitman attatched. So I would be hard pressed to believe that the box is causing the problem driving straight unless it is somehow ascilating back and forth in which case you would feel it when not moving. think about it a little it dosent make logical sense that the box is causing the problem, it may not be up to the task of dampening the symptoms, but it is not the basic problem.
somewhere in your system there must be angles of force combined with "slop" that cause vibration at the requency which nodes and antinodes meet (certain speed) the effects compound and you get dangerous death wobble. you would likely be able to speed up and have the wobble dissapear, but don't try it because it would be very dangersous as you know.
Good luck!!
Jetboy said:
You may want to spend the $40 to have an alignment done on a lazer alighnment rack. for the money it may be teh best way to figure out what is wrong with you allignment/steering setup.the hunter systems have a very detailed accurate measure that could give you some insight into your pproblem. they are also a good way of finding minor slop the mechanic will be able to help locate problems. Good luck!!
I used to use a Hunter "LightAligner", the predecessor to the LazerLiner. They are good machines, but a lot of what you see is designed to sell wheel alignments to customers. Since they depend on hanging a light off the wheel or hub they are only as accurate as the run out of the wheel. This is something that the mechanic is supposed to check and correct for, but most don't take the time.
About half of the cars that came into the shop didn't need any adjustment, but shop policy was to leave it on the rack for 15 minutes, bang on the frame a few times, take it off the rack and tell them that it was aligned. That is because everyone in the shop (besides myself) was an ex con felon. It was the only job they cpould get where they could keep on stealing and not go back to prison. I was the only one in the shop that had taken trigonometry and it pissed them off that I could calculate the size of the shims to adjust the angle instead of guessing. I never told them how to do it so I could get the cushy job lying on my back listening to the radio. They could have found out by reading the manual for the rack, but they didn't bother doing that either.
Pin Head, I know where your coming from. around here there are good and bad mechanics, but I live in a small 50k town so everyone knows who's good and who's not. so it would be easy for me to take it to someone I know that would let me work on it and watch the results as well as play with it a little, but i guess in a bigger city that would be hard to do.
I'll probably take it in to have the caster and such checked once I confirm that the wobble persists with the new box. Another thing I'm thinking of doing just to be sure, is to remove the springs and check the bushings.
But here's a question. If the factory spec for castor is one degree, what good does increasing the castor to 3 or 4 do? Shouldn't you be able to run fine up to those degrees in the oposite direction?
I had another thought, just because you have positive caster doesn't mean that you will track straight. both sides have to be equal and toe and camber must be correct as well. something like a broken leaf or a saggy leaf pack could cause the problem because the axle is not running exactly perpendicular to the vehicle, thus opposing side loads are not equal. this could potentialy be caused by front or rear springs. (Especialy if they are skyjacker I have had many problems with them)
OK, just an update for this thread, I changed the box and drag link end. Tightened things up a hell of alot. The front end is tight as a bow-string. Drives straight, steers great. The box just feels tighter, it's actually not as easy to steer on the street, but has alot more force behind it when out in the rocks and dirt.
But last night, while just looking things over underneath, I found two hairline frame cracks. One directly under the box, on the under-side of the frame. Then another one about halfway between the box and the front x-menber on the inside of the frame. I don't really know if these were the cause of the DW or not. I seem to want to think that the DW itself caused the cracks, because I seriously doubt the old Scout box put out that much force. But anyways, I welded the cracks, and am gonna keep a close eye on them. If they crack again, I'm gonna pull the box, cut off my reinforcement plates, weld any cracks that may be behind them, then weld on new plates that are about a foot longer in either direction.
