Shakey mirror fix with a bracket and bottom post fix
@Outsane I'm a little confused at your explanation from your website.... "Commonly the mirrors bracket breaks on the outside rear view mirrors" outside rear view mirrors? Please explain what you mean here.
My mirror bracket is broken at one of the "hooks" that the mirror hangs onto. Will your product fix this issue?
Hooks are no longer used with the kit, yes it will fix your issue.
Thanks @flintknapper !
Trying to say that the ears of the mirror assembly break off. It can also break the bottom support off as the unit is in tension when installed with the oem parts.
Just ordered a set for both sides- between @Outsane’s shaky fix and @NLXTACY’s floppy fix my mirrors are going to be tighter than…well, I’ll leave it at that, it’s a family show.
"Bark on a Tree"....right?
...a 10" on 300 rms in a 7th-order band-pass.
edit:facing rearward, in a hatchback.
@Outsane got my kit today but one of the screws is different than the other 3. Any reason why or where it goes?
Thanks! Will DM you.
i need a set for the driver side. Should i send you a DM @Outsane
Sure!
Or
Another satisfied customer.
Just installed mine on the drivers side mirror. One piece of advice...I had a cracked bottom screw boss and was too heavy with the JB Weld to make the repair. I ended up using a Dremel to trim out the excess so it would properly fit.
All in all, it was too easy. Thanks Outsane!
Bought one today for my new-to-me LX. Wish this had been around when I had my '93 back in the day!
Just ordered, both sides need the "fix".
Great product. My shakey mirror is no more. Took about 10 minutes working leisurely. Had to slot one tab on the mirror assembly.
