Servicing stiff dash/pull knobs
PNW, WA aka wetside
My pull knobs for the fresh air, warm air, and fan are really stiff.
How do you go about servicing these?
Thanks In Advance
Warm air is likely a bad heater valve. (mounts to engine side of firewall at the back of the head. Get one from Toyota.
I would check for stuff in the way of the fresh air flab that is direction below the fan motor. Might want to disasemble the heater fan and lube the flap.
Most of the switches are somewhat serviceable. Just pull them out of the dash and see what some good oil or white lithium grease can do.
it's best to pull them as much apart as you can.
the housing as well as the "cable" are likely to be fairly rusty.
clean it off the cable(they are more like wire than cable).
and hose out the housing with wd40 or the like.
then lube and re-assemble.
it they are too far gone, replacement is the only real other choise.
I used bicycle chain and cable lube on the choke cable, pulled the knob out, shot it full of lube, and pulled it in and out a few dozen times. that would probably work on your cables. For the switch, you can get products that are made for cleaning/lubing switches and contacts at radio shack or that kind of store, though I would just use wd-40
WD40; for the fresh air pull, I would make sure it is not bent somewhere.
I'd use something like 3-1, lithium grease or the like. WD40 doesnt actually work for the long term.
