- Thread starter
- #21
The residual valves for the NA 4wheel drum spec hold a higher residual pressure than the ones for disc brakes. Disc brakes do not have the same spring mechanisim that drum brakes and therefore do not push back as hard. The 10lb valves can, not always, cause issues with disc brakes not returning to rest due to line pressure remaining too high. You can either remove the one for the circuit that runs disc brakes (NOT THE DRUMS!) without problem. A 2lb valve is available to replicate for discs what the 10lb valve does for drums.
At least that's what I have read.
I know what you're saying. -Perhaps the NA spec mastercylinders have "valves" that do indeed maintain a "residual pressure" in the brake lines.
But mine don't/can't. So my valves can't be assigned any "pressure rating" at all. (They are not 1 psi, 2 psi, 5 psi or anything like that.)
