Secrets to cleaning up an engine?
Tulsa, Okla
Bought rebuilt 2F off another mud member to transplant into the 66 45LV. However I want to give it the appearance it is new so curious if anyone has any special solvents, degreasers and recommendations for doing this
Right now I am removing all the accessories to take to the powder coating shop. The valve cover with also go to the powder coating. I am looking to clean and pain the block and oil pan. Right now I have some heavy duty citrus degreaser and small wire brush. I am curious what other have done and what high temp paint you used?
Cheers!
Lots of degreaser and a wire wheel on a drill to finish everything off. Then I wiped it down with wax and grease remover. I put pieces of sponge in the spark plug holes and taped them off and taped all the other holes. What a pain in the arse!!! I used the following paint and there was a engine primer and clear coat. 3 coats of each. I went with Cast Iron color and I like it but wonder if black would have been better:)
Elbow grease. I like simple green in the gallon jug, throw it into a spray bottle and it’s a lot less expensive than buying the smaller bottles. Brake cleaner, scrapers and a wire brush on a drill help a lot too. I think it’d save time to just tear it down and drop it at the machine shop......
Yeah unfortunately not best option, closest one is 3 hours away.
I'm scraping away for sure. Elbow grease being the key word here.
Thanks!
Wow!
Cast Coat iron- same color I used. Better to have the block a lighter color IMO so you can see any leaks. I used the cast coat aluminum on all the aluminum pieces to keep it easier to clean. I used a power washer with warm water on the lower part of the engine. Too much grease just slows the job down.
Pressure washer, that purple zep cleaner stuff, elbow grease.
I’m in short supply with the power washer. Think I could just rinse well with garden sprayer?
You can, but more elbow grease required. Spray with oven off, let it sit 20 minutes and then use a bristle brush and loosen up heavy areas. Then rinse off.( note that it will discolor aluminum, so I tend to use it on anything metal, cast iron.
A bit time consuming but I made cover plates for, manifolds, water pump, t-stat housing, fuel pump, distributor hole and starter & timing sight hole. I used gaskets to trace some of them. In a vise, I beat the insulators off an old set of spark plugs which allowed better access for cleaning & painting. I left on the valve cover and side cover but did a quickie tape up on most of them. After the block paint I pulled the valve & side cover for a separate painting. With the cover plates bolted on I had no worries getting aggressive with the prep.
Thanks!
You got a Dollar Tree near by? If so, get you some of this, Totally Awesome!
I used an old heavy-duty steam generator that I had from removing wallpaper, helped a bit - also kept me warm in the unheated shop. :-D
Past that, degreaser and a brush, although I also find that 100LL AvGas makes a good degreaser when used with care - acts a lot like brake cleaner, but $4/gal vs $4/can but obviously a bit flammable.
