Second fuel tank???
TRAVERSE CITY
Guessing the rear fuel tank is not factory option? I been using the org. tank under the seat. Any thoughts would be helpful.
the tank was added at some point by a PO. not a factory option
are there any lines hooked up?
they should go up the frame rail to some sort of switching valve.
The rear tank appears to be a Con-Ferr because of the sloped angle at the rear bottom of the tank, and because of the shape of the filler neck. There are guys here on Mud that can post up the drawing of the plumbing/routing for you.
Interesting someone put earlier jump seats in a ‘74.
Suggestion: drain and remove your aux. tank and skid plate, and I can guarantee that you will find rust between the tank and plate. Do it ASAP and then paint/rustproof those surfaces.
Good point! I just wanted to make sure this want a factory option.
I'd keep the tank and put a tidier filler with a stock door. I really apreciate having a range of 400 miles on a bad day.
