Scary Chit
Hey - look at the top of the connector for a 5 digit number. May need a magnifying glass or that iphone app to read it. Then add 90980 to the front and that's your part #.
Another reason to drive a diesel.....
Thank you for the post. I looked real hard at this connector and unfortunately, there were no numbers to be found. As such I am still looking for the connector.
I did find many universal fuel pumps dirt cheap on amazon that say they fit the 80. They look the same and include their own pigtail. I am now thinking about just swapping the pump to the universal. Any other options out there? What do you guys think?
Look 360 - the 5 digit number is on the connector. Sometimes really hard to see or hidden - but it will be on some edge or lip visible only with a magnifying glass
I'd want to know....before I ordered a universal.
OTOH, you can always return something from Amazon. So there's that.
It's not totally a "Universal" I guess I stated that wrong. Amazon states it works for 97 fzj80 and it looks pretty darn close to the original in design but it is an aftermarket part and really dirt cheap like $25. I guess what I am asking if anyone has used these aftermarket pumps and given a warning to stay away.
I looked 360 really hard. I popped the clip out of it and got really close up high res. The number is not there. Only some symbol, a number 3 and another symbol. You can see them in the pictures below.
So if someone disconnects their faulty vapor canistor and vents
the gas tank to the atmosphere, does that mean enough atmospheric
air (21% O2) will get into the tank to allow combustion to take place??
Yes, that's possible, but unlikely due to the vapor pressure of the gasoline and the fact that it continuously vaporizes and fills the tank with fumes.
OP: Check with @slow95z , as he may have harnesses and pumps (used) that you could buy. He parts out these trucks.
This would be a good time to cut a flap hole above the pump for ease of future access to the pump. That's all I got!
? There is already an access panel to get to the pump.
Well, you're close. The carpet has to be pealed back to reveal this access panel. Some of us have so much s*** piled in this area that pealing the carpet back is a major PITA, hence my suggestion of cutting a flap right over the access panel. It makes the process of simply checking your pump once in a while just to make sure no over heating connectors or the condition of the fuel pump sock a *tad* less PITA.
Get a load of this, the dumbass who designed the access panel in my 4runner made the hole too small for anyone to pull the pump through :bang:
Is it possible then, that the pump you took out is not OEM?
That’s definitely not an OEM connector.
It is an OEM Connector and an OEM pump. I have owned this vehicle since almost new way back in the early 2000s maybe 2002 the pump failed on me at the Yankee Toys Fall Gathering. When I replaced the pump I replaced it with Genuine OEM for a small fortune. The new pump coming out of the genuine Toyota box was identical to the original and the connector plugged right in. This is also one of the reasons I am reluctant to go the aftermarket harness and pump today.
It has no numbers on it
Chris Thank you for the confirmation. I guess at this point, if nobody else has seen this connector anywhere, I will give up looking for it and put in the $25 amazon aftermarket pump with the connector it comes with.
Gotta Love Prime. Cheap and quick! Just the way I like it! :D LOL Anyway, the pump and connector look darn close to stock with one exception. The spade terminals have been upgraded. Dare I say maybe the Chinese knock off company recognized a deficiency in the Toyota design?
