Scary Chit
So I have been troubleshooting a PO171 code for quite some time. I have searched and tried pretty much every possible cause with the exception of swapping the MAF. The latest item I checked was the in-tank fuel pump and sock. What I found will shock you. The connector to my fuel pump has melted inside the tank. Yes, The negative side of the connector had gotten so hot the plastic it resides in has melted and partially disintegrated. The terminal ends themselves don't look much better. When I think about it, it's kinda scary! Anyway, It is not going back until the connector is rebuilt.
Does anyone know where I can find the proper connector to splice back into the pump assembly? Pictures are attached.
Brother's 95 wouldn't start, traced it to a bad electrical connector on the same plug. If you find a proper plug and terminals that fit the OEM fuel pump, let us know!
Some where there is a list of all the plugs on here, also the FSM has them too
I know, as a matter of science, that liquid gasoline is not the same thing as vapor.
I have heard other people say the same thing to justify placing an electrical pump inside a fuel tank. What we all need to realize that quite often the entire tank is nothing but gasoline vapors. The 25 gallon 80 tank is terribly small for a vehicle that realistically gets about 12 MPG. If I did not run my tanks to empty before refillling I would spend a lifetime on line at gas stations. The height of that connection in the tank is roughly the halfway mark. As a matter of science, that means 50% of the time that connector is sitting in gasoline vapor. :eek:
Hey it was just arcing a little :flush:
Is that kinda like just putting the tip in? :D
Will do please do the same.
Thanks guys for the info and links. I tool a look at them and downloaded the pdfs. That is good stuff but unfortunately I am still not able to determine which is the proper connector I need for the fuel pump and how to order it.
Any other thoughts?
If the FSM falls short, check the body of the failed plug for a series of numbers and/or letters. That connector number can be looked up. The Denso connector catalogs would be a good place to start.
It's only a problem if oxygen gets to it.
Fortunately, it's off when you stop to fill with fuel, then you fill it with liquid past that point.
Now, if you had the cracked tank syndrome along with that.......THEN you should worry a bit more.
Vapor to o2 ratio still needs to be within the LEL, and UEL to combust however.
Since explosion is such a non-issue in there which one of you guys wants to cut off your connector and swap with me?
Waiting... Waiting... I thought so.... :D
Why would I do something silly like that?
Yes, you were VERY fortunate that all that melted was the plug.
Is it eh one on the PUMP side or the Harness side inside the tank? I'm guessing the harness side inside the tank or else you would have just swapped the pump and moved on......duh!
I like to live on the edge, but then again, I would assume if it were a
problem we would have known about it by now??
I totally agree that I wouldn't want to be the one experimenting on a live fuel tank just to prove a point - a lot of stuff can go wrong - but this is instructive:
(note gas is turned on when the sparker is lit off).
So if someone disconnects their faulty vapor canistor and vents
the gas tank to the atmosphere, does that mean enough atmospheric
air (21% O2) will get into the tank to allow combustion to take place??
Hey - look at the top of the connector for a 5 digit number. May need a magnifying glass or that iphone app to read it. Then add 90980 to the front and that's your part #.
Another reason to drive a diesel.....
Or drive a Cummins diesel and it has a lift pump and you toss the Toyota electric one in the Bin :meh: :flipoff2:
