Scangauge II mount
Outsane
Supporting Vendor
San Mateo, CA
Website
solvefunction.com
I was asked to make a scangauge II mount so here it is.
I pushed it back as far as i could to give the best chance of seeing your cel. I am still able to use full tilt of the steering wheel. Cable routes out the back and down the steering column, nice and clean.
View attachment 2138154View attachment 2138155View attachment 2138156
Does the scan gauge show water temp and Trans Temp? where is it hooked up to? Any Help appreciated!
Scan Gauge II This link will show you everything it reads. It plugs into the OBD2 reader in your fuse box. If you search around, there are a lot of good installations.
does this mount effect the tilt?
Have been wanting to get a Scan Gauge, this provides the motivation...how to purchase this mount?
Coolant temp and ambient. I think our ECU doesn't easily allow trans. temp. too bad.
Still like having mine for piece of mind.
Would be nice to get tranny temp...
You’ll have to put in your own trans temp gauge unless you want to buy a 100 series. Then you could display trans fluid temp on the Scan Gauge with the proper coding. As far as I know, the 80 series doesn’t provide that info to the OBDII plug like the 100 series does.
Nice mount by the way...
It does not show trans temp. You can add a system to do that, but unless you tow regularly or have some other pressing reason to monitor trans temp, I wouldn't go to the trouble.
I added an Aux gauge to mine and to be frank, it is a very boring gauge. IF you have a healthy, properly operating transmission now AND keep the fluid fresh....you won't see trans temps that approach anything to worry about.
