Saginaw Mounting question
Maple Ridge, BC
I wanna start welding up my frame now, and I'm planning on running sag steering. Do i have to have my steering set up before i can weld up the mounting plate? I dont have any of that stuff yet, right now all I got is a bare frame. Also is there any good designs on the internet that i can copy for a mounting plate? I've seen setups where they also reinforce the right frame rail as well. How should I go about this? Oh ya its a 74 FJ40.
i would wait till you have the parts and you can hold them up to were the best places for things will be before you do any permenant attaching.
yes you should reinforce the right side, u can use just a simple plate to do this, if you need pics let me know, kurt at cruiseroutfitters has a solid plate you can use. good prices too
I just found the mounting plate design on mud. I think I'll use this, cheaper then buying one from sor. I would like to wait, but I probley won't get around to the steering for a while, maybe I'll just tack in the mounting plate.
Just put every thing first. IF not you going to have problems. you may need to cut you grend to fit. thats the problem I had. Well what bracket are you useing ?
Edit. for mounting plates I got some from georg (orangefj45 ) they are great and come for ther othere side as well
"Dont buy nothing from soa. cost to much"
I'm not, I'm gonna build this mounting plate, who is soa?
This is the brackets that I have same as the link
BC Cruiser said:
Any tips I should know?
Well cant give you to much tips. Because I'm doing it right now and i'm not done.
first just make a list of everything you going to need. and makes sure they well all work together. That's the problem I'm having right now. I need to find a new box's because of the output shaft. But what are you going to do about the shaft, make it or buy a new one, there's some few people that sell kits. everything you need to set it up. so ya just have a part list. what do you have right now ????
When you cut the hole in the front cross member for the steering shaft linkage use a hole saw so you don't end up with square corners. Cracks start from 90°holes.
I would tack weld everything together and assemble as much as you can before you weld it all up. I had to grind mine off twice before I was done. :mad:
I used Flaming River linkage parts, go them at Summit Racing.
The drop arm pitman from a TJ should fit your Sag gear box. I used one from a Wagoneer that was almost flat.
I think i'm gonna buy a new shaft, cant remember where the old one is. I've torn it down to just the frame. I'm not gonna set up my steering right now, i'm in the process of welding reinforcing plates on my frame, and thought i could weld on the mounting plate as well. But now I'll build it and wait till i get around to the steering.
"When you cut the hole in the front cross member for the steering shaft linkage use a hole saw so you don't end up with square corners. Cracks start from 90°holes."
What size hole saw did you use?
4", iirc.
:beer:
BC Cruiser said:
Do i have to have my steering set up before i can weld up the mounting plate? I dont have any of that stuff yet, right now all I got is a bare frame. .
Wait until you get all the steering parts and then just tack weld the plate in place, install the linkage and put the some weight on the wheels and check for proper operation. If it checks out then weld the plate last. It is much easier to cut off a tack weld if you need to reposition it slightly for your particular set up.
Casey @ hydra steer in port kells can supply you with a borgeson shaft and the proper u-joints for the saginaw box. You will have to cut a double -d into the cruiser shaft portruding through the firewall . I think his price was around 240.00 + tax cdn. for everything. I have done this half a dozen times now and his price is pretty good when you consider the lack of shipping and or duty.
borgenson was about 50% higher than Flaming river when I got my system together. Two u-joints and a slip shaft ran me around $100 US. IMHO the slip shaft was worth it. Before I had a soild shaft and it would bind and rub when I got flexed out.
I used a round to DD u-joint and thorugh drilled at the fire wall. I wish I had ground the DD onto the cruiser shaft, but a previous conversion to a saginaw mechanical box was done and they cut the stock shaft reall short. :mad:
